F350 V10 exhaust leak - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-19-2011, 05:43 PM
74redone 74redone is offline
74redone is starting off with a positive reputation.
I just bought a 2002 F350 CC 4x4. It has the exhaust leak on the passenger side. From what I understand this is a common problem. What I was wondering if there is a good fix for this so it wont happen again.
Thanks for the help!
Matt
Old 06-19-2011, 06:47 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
replace teh studs with bolts.
Old 06-19-2011, 10:38 PM
is it a real pain to place the studs? I know there are three that are broke right now. Is it a dealer only job? I work on CNC machinery everyday so I would much rather do it myself but thought I would get some pointers from guys that have already done this.
Thanks
Matt
Old 06-20-2011, 05:08 PM
nmocean's Avatar
nmocean nmocean is offline
nmocean is starting off with a positive reputation.
Install headers with copper gaskets. It is a PIA to say the least.
Old 06-21-2011, 01:29 PM
ordually ordually is offline
ordually is starting off with a positive reputation.
There's some good reading on this down in the V10 forum. Here's a couple with some good how to steps and remediation ideas to get you started:
broken-exhaust-studs-time-to-get-at-it
yippee-finally-broke-a-manifold-stud-or-two
Ord
Old 06-21-2011, 03:24 PM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Quote:
Absolutely!
But you can do it yourself.
460 Exhaust leak when cold i think JAMES1952 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 06-27-2015 06:56 PM
Replace exhaust manifold or headers? 5280 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 04-19-2014 02:45 AM
Header exhaust leak the5schlueters 1987 - 1996 F150 & Larger F-Series Trucks 5 09-25-2013 05:47 PM
20008 v10 exhaust leak redbull660 Modular V10 (6.8l) 11 12-03-2011 01:23 PM
Rusting bolts in exhaust manifold 94568xlt 2004 - 2008 F150 13 12-06-2010 03:09 PM
Tags
10, 2002, 350, exaust, exhaust, exhuast, f250, f350, ford, leak, leaks, problems, stud, superduty, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
