F-150 tire size? - Ford Truck Enthusiasts Forums
F-150 tire size?
Old 06-19-2011, 12:43 PM
tbirdage tbirdage is offline
tbirdage is starting off with a positive reputation.
F-150 tire size?
I have a 79 F-150 4X4, bone stock with 31X10.5's on it now and it just doesn't look like a truck. Would a 33 fit in those wells or is it too much? Please post some pics so I can get an idea of what to get. i just ordered Mickey Thompson Classic ll wheels and was looking at Pro Comp X-terrain tires. This is a show truck, I just got it out of paint last week. It'll probably never even see a gravel road again in its life.
Old 06-19-2011, 01:14 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
This is my 77 with 1 1/2" lift springs in front,,, those are 255/85/16 or 33x9.00x16 and there is plenty of room for 35's so yes you should be able to put 33's on it with no trouble, and look a hell of a lot better,,,
Ford Truck Enthusiasts Forums - Pickupmanx2's Album: Da Fleet - Picture
Old 06-19-2011, 01:17 PM
turbohunter's Avatar
turbohunter turbohunter is online now
turbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant future
Got pics of the new paint????????
Old 06-19-2011, 01:30 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Quote:
That's strange .... I've never had that problem and my '77 F-150 has worn 31/10.50-15s since at least 1986.
My speedometer is right on the money with them as well.
Old 06-19-2011, 03:56 PM
Good lookin' truck pickupman! Is that a '76 cab on your 77? I noticed the gas lid on the cab and on the bed. If i went with 1.5" lift coils, would i need to change anything else? (sway bar links, C-bushings, shocks)?? I really want to keep it stock, but yours is exactly the stance i'm looking to get.
Turbohunter, I have all kinds of pics but i never could figure out how to attach them on here. Is there a quick way to just upload one from my local pictures folder?
Old 06-19-2011, 09:28 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
It's recommended with any lift that you get the corresponding C-bushings to correct the caster.
Sway bar end links? As the owner of a 73, that's foreign to me!!! LOL.
Old 06-19-2011, 10:26 PM
79 shortbed lover's Avatar
79 shortbed lover 79 shortbed lover is offline
79 shortbed lover is starting off with a positive reputation.
this is the way i learned from chasetruck put [IMG] in front and [/IMG] behind when you post a something new. Hope this helps
Old 06-20-2011, 11:02 AM
Thanks! It's my favorite one,, but don't tell the other trucks!!
Nope,, truck is a 77, last of the in-cab tanks and also got the AUX tank!
Yes, since I was going to do the lift coils, I also did new 4 degree C-Bushings, Radius arm bushings and track arm bushings,,, They were Superlift Coils,, from 4 wheel parts,,, they had all the bushings also. I haven't changed the steering from the Y setup yet,,, Sid (the truck) only has 97,k original miles,,, so everything is still tight and if it ain't broke,,, don't fix it!
I do plan on tryin the 35's off my wifes Excursion on it when they are getting low in the tread,,, just to see if I like the size,, or if they are to much meat,,, I went with 16x8 rims,,,, HUGE selection of rubber, and I have to say,, I was wingin-it when I ordered the 255/85/16s,,, but they are a great size,, and have taken me ALOT of places!
Thanks again and good luck
1994 F150 XLT 4x4 Level / Wheels / Tires eduhat 1987 - 1996 F150 & Larger F-Series Trucks 24 05-16-2016 12:42 AM
1994 F150 4x4 Level / Wheels / Tires eduhat Brakes, Steering, Suspension, Tires, & Wheels 1 06-03-2015 11:46 AM
255-85-16 or 285-75-16 1993_f350_2013 1987 - 1996 F150 & Larger F-Series Trucks 6 10-11-2014 06:09 AM
Leveling kit and tire size? Stangfire 2009 - 2014 F150 9 02-01-2014 07:17 AM
Tire size ?? deerdude 2004 - 2008 F150 7 09-22-2008 02:23 PM
Tags
1979, 31x105, 4x4, f150, le, mans, size, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
