need help on what this engine is.....429
Hi, i took this engine out a car about 15 years ago, and am wanting to put it in a truck i have. I am not sure what it is tho. I was almost positive it said 429 on the valve covers when i took it out, but somebody took them off and the push rods. I have yet to tear it apart but when i do i can get more numbers off the crank etc. This was all original in the original car it came in when i took it out.
I am confused on the numbers on the heads, the second number is missing? It is not hard to see it is not there at all. both heads.
Block d1ve-a2b
heads... d ve-a2a
intake...d3ve-a??
Can anybody tell me if this is a good engine or one of the not so good ones?
Thanks.
I also have another 429 or so i was told. I can only get the heads and intake numbers right now.
heads...c8ve-e
intake...c8se-9425
Block d1ve-a2b
heads... d ve-a2a
intake...d3ve-a??
Thanks.
heads...c8ve-e
intake...c8se-9425
Block d1ve-a2b
heads... d ve-a2a
intake...d3ve-a??
Thanks.
heads...c8ve-e
intake...c8se-9425
The numbers I.D. it as a 73/ engine (head should read D3VE). It was a lower CR than the 68/71. 1972 was a very bad year. It is also an EGR engine and has retarded cam timing.
The second engine is a 1968 (most likely) 429/460. Just measure the stroke through a spark plug hole or a tear-down.
dirtyoffroad
06-22-2008 01:47 PM
wesley958
25
01-02-2003 02:21 PM
