oil pressure problems-1995 F150 5.8 liter - Ford Truck Enthusiasts Forums
Old 06-18-2011, 07:06 PM
gcrose199 gcrose199 is offline
gcrose199 is starting off with a positive reputation.
Some one had installed a after market oil cooler on the F150 I bought. It has 130000 miles. The cooler goes between the oil filter and the engine, it was leaking from the o-ring behind the cooler so I had my garage remove the cooler. Also replaced the timeing chain gasket and water pump at the same time. Now the engine has oil pressure issues, normal when starting up but near zero after it gets to temp. I put on a mechanical gage, it only reads arouund 10 psi when starting and zero when at temp. Befor the oil cooler removal there seemed to be no problems with the oil pressure. Where did my pressure go? Help please. Does the pressure at the oil filter read direct from the oil pump or does the condition of the bearings affect this reading?
Old 06-18-2011, 09:57 PM
deeznuts822's Avatar
deeznuts822 deeznuts822 is offline
deeznuts822 is starting off with a positive reputation.
Fram filter???
Old 06-18-2011, 10:49 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
A mech oil pressure sensor reads the pressure inside motor oil passages, nothing too fancy. I'd swap filters and see. Also might consider dropping the pan to make sure nothing is getting caught in the pickup tube.
Old 06-19-2011, 04:29 PM
Thanks for the reply. I went and purchased a Motorcraft oil filter FL820S that this engine is supposeto take. I removed a Prime POF4459 filter that is smaller and the threads are smaller. I checked the Motorcraft web site and I bought the correct filter but it wont fit. Any ideas why the filter is not correct? Thanks
Old 06-19-2011, 04:54 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
after market cooler ?
Old 06-19-2011, 05:03 PM
After marker cooler has been removed. I did a look up by VIN and it calls for a FL820S filter
Old 06-19-2011, 07:54 PM
Ater talking to a parts man we found a oil filter that fits. After changing the filter to a larger one I went from 10 PSI to 40 PSI at road speed and from zero to 20 PSI at idle. Thanks for the help
Old 06-20-2011, 09:09 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
You need a FL1A filter. The FL-820S is for the 4.6L/5.4L engine, not your 5.8L.
0 oil pressure at idle and metal shavings on drain plug Dcnnnghm 1999 - 2003 7.3L Power Stroke Diesel 10 04-04-2016 06:35 PM
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
7.3 oil pressure problem gerald broussard 1999 - 2003 7.3L Power Stroke Diesel 5 03-06-2014 09:02 PM
Write Up: Bullet-Proofing the 6.0L PSD. colo_dually 6.0L Power Stroke Diesel 22 06-18-2011 11:10 PM
Lost Oil Pressure....Diagnostic Suggestions? edzeb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 05-09-2011 03:21 PM
Tags
1995, 58, 93, cooler, diesel, engine, f150, filter, ford, installing, liter, oil, pressure, problems, pump, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
