2007 transmission cooler lines?
How do you get the trans lines out of the radiator?
I screwed the fittings out and finally got the radiator out, but on the new radiators these fittings are already in them? is it just an o ring fit?
I pulled on the lines a littel bit, but did not want to tug on it too hard.
these fittings
these fittings
I just unscrewed the big ol fittings out of the trans cooler and when I did the trans cooler fell tothe bottom of the tank! I have looked and looked and can't find anything. Biggest ford site in existence and Boone knows how to take a tranny line off the radiator.
I'm pretty frustrated. I have posted this a few times and no one answers.....
Mine didn't have a lock. It had a little plastic clip that clipped into the grove on the bi g nut screwed into the radiator. I couldn't find any info or anything on the gasket behind that nut so I just went to home depot and bought some thick rubber washers and cut them to fit. It sealed up perfectly. Ford wanted to sell me a whole radiator to get the gaskets.
Turns out mine has a tiny pinhole somewhere in the fins on the drivers side of the radiator so I needed to take mine to a radiator shop or get a new one. BUT I can't do anything with the god moines still stuck into the radiator and none seems to know how they come out,.........
http://www.amazon.com/OTC-OTC6593-Fo...dp/B004J10S2Q/
I finally figured it out. It's a shallower version of a fuel filter disco tool
Amazon.com: OTC OTC6593 Ford Transmission Disconnect Set 2Pc: Automotive
davewild
349
08-30-2020 10:17 AM
mtuck
29
02-27-2017 08:19 AM
BLWNHR
28
11-16-2015 06:37 PM
mtuck
1997-2006 Expedition & Navigator
08-20-2013 12:19 PM
