Fluid for power steering 2001 ford expedition - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 06-18-2011, 04:27 PM
cliffhanger45 cliffhanger45 is offline
cliffhanger45 is starting off with a positive reputation.
I have a new leak in my power steering system, can not see any leak from top side but looking under seems somewhere in or around the lines right near the front. I need to clean off all lines etc and see if I can find said leak. Now it seems to be empty so I need to add fluid first. What kind is used in the 2001 expedition?? Then are there any good diagrams of this system? You can not see much under there, even the lines are all pressed up agents frame etc, could be a leak caused by rubbing just not sure. If I had a good diagram showing the lay out it might help to guide me. Thank you for any help.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old 06-18-2011, 06:18 PM
High_Horse's Avatar
High_Horse High_Horse is offline
High_Horse is starting off with a positive reputation.
Part number AS260 small bottle AS261 large bottle for the fluid at Autozone.
Here's A-Z's diagram... Power Steering Pump | 2001 Ford Expedition 2WD 8 Cylinders L 5.4L EFI | AutoZone.com ...its basic but better than nothing. Your simply going to have to climb under and look.
I would suspect either the shaft seal or the line connection at the pump base. But it is possible your hose could be rubbing on a pulley. Where the lines run from the base of the pump up through by the frame there should be a wire loom retainer for those lines to keep them from the pulleys. I caught mine just in time greasing up the front. All you need to do is bend it away from the pulleys. But in your case you may need a new line which you can get for about $20 at most auto stores.
Old 06-18-2011, 06:23 PM
High_Horse's Avatar
Old 06-19-2011, 12:10 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Your owners manual says to use Motorcraft MERCON ATF in the power steering.
Old 06-19-2011, 05:58 PM
That is what i thought but they no longer make Mercon ATF i am told.
Thank you.
Old 06-19-2011, 06:17 PM
Not sure just yet but everything around the pump looks dry, only wet is right near the radiator where you can only see the two lines from the bottom. If you look from the top you see no wet on lines or any thing else at all, so there is only maybe a 6 inch area right at the driver side bottom front that shows wet, and the only thing there are 2 lines laying right next to each other, so close together you can not tell where the leak is. So i am thinking it is add fluid clean every spot that looks wet the run it and see what I can see. Funny I would think these were high pressure lines but they do not look like it, as they only have a light squeeze clamp you squeeze together and slide back and pull the wet rubber hose off the tubing.
Old 06-19-2011, 08:53 PM
You were told correctly, instead use Mercon V ATF.
Ford Announces New Replacement Specs for Mercon ATF: aftermarket News
"Effective July 1, (2007) the production and licensing for MERCON will cease. Automatic transmissions, power steering systems and manual transmissions previously requiring MERCON must, as of July 1, (2007) be serviced with MERCON V."
'99 Expedition Fuel Pump electrical circuit wagonerkl Expedition & Navigator 22 12-05-2013 09:15 PM
Can a front brake caliper have an internal leak ..non-visible externally... nor loss of any fluid... Bones Digger 1987 - 1996 F150 & Larger F-Series Trucks 20 07-09-2012 02:53 PM
F250 Mystery surge and miss retiredinstructor 6.0L Power Stroke Diesel 2 03-20-2012 06:30 PM
Power Steering Nightmare karatedavid 1973 - 1979 F-100 & Larger F-Series Trucks 13 11-02-2010 12:35 PM
the last straw Eric_F250 1994.5 - 1997 7.3L Power Stroke Diesel 24 03-24-2009 09:48 PM
Tags
2001, 46, 97, autozone, box, diagram, expedition, expedtion, fix, fluid, ford, leaks, power, pump, steering, string, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
