1994 ranger hub and transfer case questions? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-18-2011, 10:43 AM
johull johull is offline
johull is starting off with a positive reputation.
I have a 1994 4x4 supercab ranger with the 4.0, push button 4x4.
question 1. does anyone make an aftermarket manual hubs for this truck?
question 2. when I push the button for the 4x4, it will move the transfercase motor to the 4x4 position and then right back to two wheel drive. I have a brown wire hanging off the trasfer case (seperate from the motor wire plug) which I am thinking might be to a sensor to tell it that its in 4x4? maybe it's not getting signal there for its going back to 2 wheel drive? oh and the transfer case motor is brand new.
any help would be great
thanks, johull
Old 06-18-2011, 09:37 PM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
yes, both warn and milemarker make manual hubs for the '93-'97 series ranger. you also need the spindle nut kit for the manual hubs as well. mile markers are the cheaper way to go (about 180 for the set last i knew-at autozone) the nut "kit" gos for about $50 new. might be able to find at a junkyard. i think the brown wire is for the speed sensor, so that it wont go into low range unless its stopped, not entirely sure on that one. there is a control module for the electric shift 4x that may be the cause of your problem, dont know much about it, just that it exists. i found this at another forum i read often, if your able to troubleshoot with a voltmeter this may be able to help. CLICK->http://www.therangerstation.com/tech...Transfer_Cases
Old 07-13-2011, 09:26 PM
ok I fixed the motor for the transfercase, you have to actually adjust the positioning that tells it when it is locked in or not, really easy fix.
96 f.150 electronic 4x4 issues jesseprince94 1987 - 1996 F150 & Larger F-Series Trucks 11 07-07-2015 10:45 PM
1997 Ford Ranger 4x4 not working Trey Stoffel Ranger & B-Series 2 05-16-2015 01:23 AM
1992 F-150 Transfer Case Swap Push Button to Manual Shift 4x4 Muddbugn1 1987 - 1996 F150 & Larger F-Series Trucks 5 01-09-2014 04:43 PM
does anyone have any interest in a 75,000 6.0? johull 6.0L Power Stroke Diesel 15 04-12-2010 04:58 PM
2000 f150 rear end..help please!!!!! johull 1997 - 2003 F150 5 02-20-2010 09:52 AM
Tags
1994, 4x4, atlas, case, ford, linkage, location, manual, nut, pictures, ranger, sensor, speed, spindle, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
