Warn premiums lock outs
So on my 97 crew cab with a Dana 60 I think I kinda maybe just a little trashed a set out premium warn lockouts I have one side that keeps kicking out of engagement I really really need this truck to stay in 4x4 when I want it it does have a locker in the d60 but I also need it to come oit of 4x4 to I'm pretty sure warn preiums are the best and I did buy this truck with them already installed so maybe they are installed righT
Do they both have the big coil spring in them that pushed the round gear out of engagement. It goes under that gear and a single screw holds that gear on when you take the hub body off. If it doesn't look right then I think those parts are included in the warn rebuild kit. Not sure though, I've only seen pictures of them. I've never had problems with my warns.
Are you sure it's kicking out though? I have alocker in the back of my 350 and that thing tears tires up, on tight turns on pavement, it pops like crazy as it momentarily disengages. THis is the only truck I have ever owned that wears out rear tires faster than fronts. I'm just wondering if what you are feeling is the differential working. Mines a detroit locker and they are known for noise like that.
Peavey1986
03-26-2017 08:39 PM
Lloydable
13
08-03-2015 11:09 AM
alpine7572
1978 - 1996 Big Bronco
19
09-28-2002 12:17 AM
