Double Gas Tanks on a 1981 F100
Old 06-17-2011, 05:25 PM
Brown Mule's Avatar
Brown Mule
Brown Mule is offline
I can only get 1 of my gas tanks to feed to my engine (back tank) and the other will not feed. How or what must I do to make this work again. What should I check. Please help.
Old 06-17-2011, 05:48 PM
Brown Mule's Avatar
Brown Mule
Problem with Double Tanks on a 1981 F100
Need help solving my problem with my double gas tanks on mu 1981 F100. The back tank will feed the gas to the engine but the front tank will not feed the engine when I switch to that tank. I have gas in the tank. Please help.
Old 06-17-2011, 05:55 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Two threads on the same topic have been merged together.
Old 06-17-2011, 08:43 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
Check the lines and the valve along the driver's side frame rail, about under the driver's door. Make sure the front tank lines are hooked up and that the valve is switching.
Old 06-18-2011, 03:04 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
The rear tank is default on the selector valve solenoid located on the Drivers side inner frame rail. It's means of ground is where it attaches to the frame. There should be one brown/white stripe wire feeding into it.
With the tank selector switch in the dash switched to Front, you should be getting power to this wire at the selector solenoid. Use a test lamp, with the ignition switch placed in run with the engine off. If power at the Brown/White stripe wire, try cleaning the ground to the solenoid by unbolting it from the frame and using sand paper to make metal to metal contact, then reattach the solenoid. You can use dielectric grease to help fight future rust issues where the solenoid and frame connect.
If you have power at the Brown/white stripe wire, and cleaning the solenoid contact to the frame doesn't work, you most likely need a new Fuel Tank selector solenoid.
keyspirate
6.7L Power Stroke Diesel
16
03-29-2017 08:21 PM
Thenewboss
08-10-2015 01:07 PM
calixt0
07-10-2015 07:13 PM
Cdashner
10-12-2014 07:02 AM
StanleyZ
6.4L Power Stroke Diesel
16
10-23-2013 05:47 PM
Quick Reply: Double Gas Tanks on a 1981 F100
