Popping noise under feet while going over a bump
99 F350 4x4. I have a popping noise while going over a bump or sometimes when turning. You can feel it in your feet.
All of my steering components are new and tight, along with my track bar bracket.
Guys at the tire shop looked at it and said my swaybar bushings might be bad?
I crawled under it and four of the bolts that hold it to the frame were pretty loose so I tightened them. Popping noise did not go away. Any ideas what could cause this?
Sway bar end link bushings... Had the same problem, installed these http://www.riffraffdiesel.com/mm5/me...e=F731-SUS-ENE ... and gone!! easy to do and will solve that annoying problem.
noise
Sorry for asking about 2wd or 4wd dont know how i missed that......
I have the exact same problem, I live on a dirt road in a rural area, and that's the only time I hear it, unless I hit a hole or large bump. I was told by shop it was my upper/lower ball joints, but I am thinking it might be my shocks. Gonna replace my shocks first, they have life time warranty, lol, and it's been quite a few years and mile snow, if I still hear it, then I am going to look into the ball joints.
I have the same noise. I changed all ball joints, tie rod ends, steering linkages and sway bar end links and did the shocks and still have the noise. I even changed the nylon spring pads under the springs to see if that would help. No luck with any of it good luck with yours.
Leaf spring bushings are next.
jeepfix
1997-2006 Expedition & Navigator
08-22-2015 09:18 AM
