Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 06-17-2011, 08:23 AM
dhudson06 dhudson06 is offline
Garage is empty, add now
dhudson06 is starting off with a positive reputation.
Talking Growling Noise on high idle
I have a 2000 f150 supercab that i just upgarded to Lightning. i purchased a wrecked 2001 lightning off of ridesafely.com and swapped everything ( i mean everything) from fuel tank to wiring harness to total re-end... so long story short. after i figured out the drop resistor thing she fired right up and runs good. Only thing that is a concern is when engine is cold or air is on, when it kicks up to a high idle there is a growling noise coming from air intake... if i kick it down it stops. I say it acts up only on high idle.. but it will make that growling noise when cruising slow. sounds kind of like something is not seating right meaning not holding the vacum right. i was reading in service manual something about make sure to notice return spring on throttle cables orentation when removing because it needs to be put back on like it was ( spring? i would think it would only go on 2 different ways and neither seem better than the other). Also they say something about superchargers bypass being installed with installation tool/gauge? it only has a little adjustment but o never know. Any help?
  #2 (permalink)
Old 06-18-2011, 04:58 PM
STOFFERJ STOFFERJ is offline
STOFFERJ is starting off with a positive reputation.
Probably a dirty IAC
  #3 (permalink)
Old 06-20-2011, 08:56 AM
have a new one on there, but does not mean that one is not bad... i will put old one on there and see...
  #4 (permalink)
Old 06-21-2011, 09:26 AM
Fixed!!! it was new IAC. well not really the IAC but the gasket Holes where smaller than the old ones. So it actually was sticking out in the air holes making a terrible humm at idle. Thanks
Tags
2002, 2005, 46l, air, box, escape, f150, ford, growling, high, idle, intake, making, noise, sound, vacume
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
