Gotta Love That "Christmassy" Feeling.... Parts Incoming!
Well, I officially have all my parts coming in for my Pedestal O-ring replacement job!
Guzzles Price of $20 for the turbo reinstall kit beats the hell out of Ford's price... of $86.
Am I missing anything? Anything else to do while the turbo is out?
It's 2am as I type this and I'm tired.... hopefully I have thought of everything.
Soon as I get the leak stopped and the engine/compartment cleaned up, (LOTS OF DE-GREASER!) I plan to get the tools out and clean up the oil pan, sand it all down and paint it up real nice. Hopefully this will get rid of my oil leak and be the end of unwanted corrosion on my oil pan!
Night Folks!
- Turbo Re-Install O-Ring kit from Guzzle. $26.45 (w/compressor gasket)
- Wicked Wheel from XDP. ($77.50)
- Non-EBV Pedestal. ($75 Ebay)
- Turbo Master (Dieselsite $160)
- Fumoto Drain Valve (Dieselsite $27)
- AIH Delete Plug (Dieselsite $8)
Night Folks!
When you say Up-Pipe Gaskets, what exactly are you refering to?
I don't want to remove the up-pipes unless I have to, and I do not have any leaks at the moment. (Over 30psi Boost) When I do replace them, I'm thinking about doing all the piping, manifolds, etc.
Do I need to replace then when I pull the turbo? Where is the best place to get them?
I apreciate the help!
The front of the valley is dry, and since my CCV I havent noticed any oil on the intercooler tubes/boots. (TONS when I got it) so I'm planning on taking it apart some more and cleaning it up real good...and maybe doing a little paint.
Night Folks!
Night Folks!
If you don't have any leakage or movement at the y casting where the turbine inlet connects then you're golden, if you do there are two (one each side) do not gaskets sandwiched between clamps on that casting,that seal the up pipes, ther are by far easiest to service with the turbo pedestal off or engine out would do them now loss than 40.00 from your local Ford store for the pair you only have to remove the combined flange the up pipes stay on the truck. Also while you're there tighten you're exhaust manifolds too! Be sure to inspect you're passenger side fuel feed line as it goes into the intake manifold clamp as they are notorious for wearing through at this point, replace it if there is any indication of wear also there are some good replacement bushings available from site supporters to stop the "rub through" problem, last thing brake cleaner works great to clean out valley also removes diesel oil spots from concrete driveways! Don't forget to poke out weep hole at far back pass. Side rear for correct drainage subsequent cleanings can then be done with power purple, simple green ect and water on a regular basis to keep it nice and clean! I hope this helps clear up your questions have fun
As of now, I have no leaks that I am aware of. I'll know for sure when I get the turbo out.
You lost me.
You're talking about the collector pipe, right? I don't plan to remove it unless it has a leak....
NO!!! They are rusted as hell. (Too many New England Winters.) They aren't leaking, and I don't dare touch them until I replace them. I had a buddy go through this on his 2000 F-150.... Had to replace both because a stud snapped.
I was NOT aware of this, thank you! I will definately check it out, do you have a pic for refrence, just in case I can't find it? Thank you!
The Valley-Drain? It's clear, but I'll make sure when I get it all spiffed up. I actually have a good biodegradeable degreaser I'm using, seems to go good.
You lost me.
The fuel line that rubs is the line that goes from the fuel bowl to the passenger side head. You can see Guzzle's pics in this thread: https://www.ford-trucks.com/forums/9...el-leak-2.html
Edit: this thread has some great info about common problems with our trucks: https://www.ford-trucks.com/forums/1...on-thread.html
Well, I was thinking about it, and I decided to buy the Plenum Reinforcing Inserts and 4 T-bolt Clamps from Guzzle, too. (Wish i though of it the other day when I ordered)
I checked out Clay at Rifraft and they were a little more expensive, (a couple bucks) and I don't have an account with them yet, So I went with Guzzle. Guzzle has been fast to ship so far and reliable!
So Add another $72 to the list.... But the intake Pleniums wont colapse on me now, and I can lose those crappy worm-drive clamps and have a better sealed system!
Question:
Can't wait to start digging into this thing...BUT: Does anyone else have an opinion on how to gut the exhaust outlet housing? I'm thinking just cut it out and tap a couple plugs in it to seal it.
Question:
Total for everything, including shipping, is $465 so far:
Wicked Wheel (XDP)
Turbo/Pedestal Gasket+Bolt Kit (Guzzle)
Non-EBV Pedestal (Ebay)
Plenum Reinforcing Inserts (Guzzle)
(4) T-bolt Clamps (Guzzle)
AIH Delete Plug (Dieselsite)
Turbo-Master Boost Controller (Dieselsite)
Fumoto Drain Valve (Dieselsite)
Hopefully this is it for a while, and fixed my oil-drip issues. I already have the paint for my oil pan, and just need some sander-discs for my grinder to clean the oil pan up. Just need to pick up a pack of resistors from Radio Shack.
The only other mods I NEED to do this summer is going to be Hutch/Harpoon, and hopefully next month. Still not looking forward to dropping the tank.
Wicked Wheel (XDP)
Question:
Question:
I just used a 3/4 inch deep freeze plug from Napa.
Here are the instructions I used: Gutting the Exhaust Back Pressure Valve - 1994-1997 Power Stroke FAQ
