Rear wiper arm
Oops, just realized I mistakenly tried an Explorer arm. My bad. Might try Expedition next, but the design doesn't look right.
Here's what I've tried with no luck (both purchased on Amazon)
Too long: .
Hole for screw was too big: .
Waiting for this to arrive from China (via eBay):
Ford Focus MK2 2004-13. Seemed to have the threaded bolt hole like the OEM arm, so hoping it will do the job.
I haven't been able to find Focus rear wiper arms for earlier years, so fingers crossed.
I may also try . But not optimistic based on the design in the photo - it has that plastic piece that's perpendicular to the arm.
Too long: .
Youtube should have the answer, if my description doesn't make sense: The base of the wiper arm has a plastic cover that hides a bolt and nut. This is where the arm attaches to the window. Just pry the plastic piece off to expose the bolt/nut, and then you can loosen the nut (it can be tough to loosen). I forget what size socket it takes, but it's a standard size.
Quick update, the Focus wiper arm looked to be about the right size but the bolt hole was a little too small. Also tried the Expedition arm, which a previous commenter had (tentatively) suggested. This did not work, unfortunately. The bolt hole was too small (but close enough that my backup plan was to try to 'force' it on there somehow.)
For context, original issue was that the rear wiper had a gap in the middle of the blade that wouldn't wipe. My equipment was the original arm and a 17-inch Bosch Icon blade.
Going back to an original size 16-inch blade solved the issue. I put back on the original arm and a 16-inch "Trico high mileage" blade I stumbled across at AutoAdvantage. The package says it's a beam blade design and has a coupler that claims to distribute pressure better. Works like a charm.
If you don't have any broken parts (like a busted spring or spring attachment point) then try freeing up the arm pivot with some penetrating lube, then follow it up with some drops of light oil. I'll wager the action will improve.
The following 2 users liked this post by GregA:
