P0236, P0500... Update: New VSS still throwing P0500 - Ford Truck Enthusiasts Forums
Old 06-16-2011, 05:22 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
My truck's threw me a P0236 code. The code apparently means "Turbo Boost Sensor A Circuit Performance". What problems should be evident based on this? How do I fix it? I haven't noticed any turbo-related problems. I'm going to clear the codes and drive it and see if the issue is resolved, or what.
The other code is P0500, which is "Vehicle Speed Sensor Malfunction". I thought I got all those issues taken care of, because I recently replaced the VSS. This could be the root cause of my transmission troubles. Like I said, I'm going to clear the codes and see what happens. What brand VSS do you guys recommend that won't give me any problems? I'm not having any luck.
Old 06-16-2011, 05:44 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Ford for the VSS, don't know what to tell ya about the 0236. Where did you get the VSS before?
Old 06-16-2011, 06:00 PM
BuckHammer's Avatar
I went through four or five BWD brand sensors from Advance, and then got a Dorman brand sensor from RockAuto, which is still in it.
P0500 must have been the code it was throwing when it went into limp mode the last couple of times, which means that the transmission problems must be simply due to the VSS. In my line of thinking, I had eliminated that as a possibility, since I had already got it straightened out.
Oh well, the computer's telling me that was the problem, but I reset the codes and drove, and now my truck's only throwing the P1111, which is the "No Problems/All Clear" signal. I'll drive it until the transmission messes up again, at which point I'll order a Motorcraft Vehicle Speed Sensor. No more cheap parts for me.
I still don't know what to think about the P0236, but it's not there since I cleared the computer. We'll see, I guess.
I still want to do a manual transmission swap, but it's not nearly as urgent now.
Old 06-16-2011, 06:55 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
On the p0236 check the hose to the intake from the MAP sensor. Look for holes in the hose or it could be clogged. R&R if necessary.
Old 06-17-2011, 12:29 AM
BuckHammer's Avatar
Where's the MAP sensor located?
By the way, I drove it to and from my friends house, which is a pretty good drive. When I got to his house, it was still P1111, and when I got home it was P1111. All clear for now, I guess. I still want to look into the P0236, though.
Old 06-17-2011, 01:06 AM
pjwoolw's Avatar
Passenger side firewall up high. Follow the rubber hose from the intake.
Old 06-17-2011, 02:26 AM
BuckHammer's Avatar
Thank you. I'll take a look tomorrow. I tried to rep you, but you know how that goes.
Edit: Just ordered a VSS from the Ford dealership. I'm going to pick it up tomorrow.
Old 06-17-2011, 05:41 AM
Got him for ya Joseph
Old 06-17-2011, 08:20 PM
BuckHammer's Avatar
You guys might find this interesting.
Okay, so I got a call this morning, and it was the dealership that I ordered that VSS from. He said that the part number that I gave him, which was the one in the "PSD Part Numbers" thread (F85Z-2L373-AB), was not a current part number. He said that that was the old VSS number, and they've updated the part and/or part number. This carried the retail price from $18ish to $40ish. The new, updated part number that he gave me is F85Z-9E731-AB. Perhaps an edit to the part number thread is in order. I didn't go ahead with the purchase, because I think I may be able to find a Motorcraft sensor less expensive elsewhere.
So, what is the difference, if any, between the new and old VSS?
I haven't had a chance to check the hose from the intake to the MAP sensor yet. I may get on that tomorrow morning, but probably not...
By the way, I try to rep everyone who participates in any of my threads, but most of the time, it won't let me.
Old 06-19-2011, 11:01 PM
BuckHammer's Avatar
Nobody's got any ideas about the difference in the VSS part numbers?
(this is a bump )
Old 06-20-2011, 12:59 AM
pjwoolw's Avatar
I would think none. Part number F85Z2L373AB was superseded by part number F85Z9E731AB. From partsguyed.com.
Part numbers change from time to time. Nothing to be concerned about.
Old 06-20-2011, 01:13 AM
BuckHammer's Avatar
Oh, okay. Understood. Why would that make the price go up, though?
Old 06-20-2011, 01:21 AM
pjwoolw's Avatar
They are about 22 bucks from Ed. Plus shipping. At the dealer you never know. If you have a part number check Ed's site first for a price. Or Tousley and silverstate also. Most are the Ford parts sites will have slightly different prices. Going to a near to you dealer the price is likely going to be higher. Unless you know somebody there.
Old 06-20-2011, 02:56 AM
BuckHammer's Avatar
I already ordered one from Ed, I was just wondering if there were any differences that would justify the increased expense at the dealer.
Thank you for straightening me out on that.
Old 06-20-2011, 05:36 AM
tjbeggs's Avatar
tjbeggs tjbeggs is online now
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
IN my experience price changes either reflect a new supplier for the parts or a decrease in stockpile of the part before Ford obsoletes the part from their system.
Speedo/VSS/P0528/P0500 HELP Devilmanak 1999 to 2016 Super Duty 11 02-07-2017 12:00 AM
Code P0236? Kelly MT 1994.5 - 1997 7.3L Power Stroke Diesel 2 06-06-2012 06:41 PM
Speedometer and ABS issues 99 F350 V10 alexs223 1999 to 2016 Super Duty 3 12-18-2011 09:45 PM
01 F250 VSS problem 02whtmax Modular V10 (6.8l) 3 10-29-2011 04:39 PM
ABS light and speed sensor DDPJ 1994.5 - 1997 7.3L Power Stroke Diesel 0 06-05-2011 10:39 PM
Tags
60, code, diesel, e40d, excursion, ford, malfunction, p0236, p0500, powerstroke, sensor, speed, trans, trouble, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
