1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Adding Limited Slip to 2011 Super Duty?
Old 11-21-2011, 02:21 PM
Baja16's Avatar
Baja16
Baja16 is offline
Any one know if somebody's making a Limited Slip differential for the new Super Duty's? I've been looking at a new 2011 Ford F-250 4X4 and i like everything about the truck but they put regular (non locking) axles under it. I looked around a little bit but i cant find anyone who lists anything newer than the 2009-10...
Old 11-21-2011, 03:03 PM
maverick22's Avatar
maverick22
maverick22 is offline
If you're looking at a new one on a dealers lot, I'd just order one equipped how I wanted it. You can get a factory electronic rear locker which would be better than a limited slip anyway. That said, AFIK the rear axle is still a 10.5" sterling, so I would think any of the aftermarket ones for older trucks should still work. Hopefully somebody will correct me if I'm wrong.
Old 11-21-2011, 03:55 PM
dkf's Avatar
dkf
dkf is offline
As far as I know the rear axles have not been changed on the F-250 and F-350 for 2011. The place that sells the diffs like Randy's Ring and Pinion or Bronco Graveyard could help you out. I'd be looking at a Detroit Truetrac if I were you. Much better than the stock LS unit.
Old 11-22-2011, 05:47 PM
Baja16's Avatar
Baja16
Baja16 is offline
Cool thanks for the info guys! I would prefer to run a truetrac if i choose this route... This Truck is a leftover on the lot a their really willing to deal but it doesn't have locking axles which sinks, so trying to figure would it would cost to at least change the diff. in the rear end...
Old 11-22-2011, 06:41 PM
dkf's Avatar
dkf
dkf is offline
Pretty sure the locking diff that came with the trucks only locks in 4wd and when doing 20mph or under. Better off with the truetrac or aftermarket locker IMO. I like to have something that works all the time and when needed.
Old 11-23-2011, 01:19 AM
EODguyJake's Avatar
EODguyJake
EODguyJake is offline
Fulltime INFIDEL!
Haggle for them to put a TruTrac in it. Or, at the very least, install it. I love my TruTrac, BTW.
Old 11-23-2011, 07:32 PM
Baja16's Avatar
Baja16
Baja16 is offline
ok i talked to the dealership and a local guy who is mostly known for doing rear end work... I guess they changed the splines in the axles shafts on the 2011 and newer trucks. My only option is getting something through Ford, but it can be done. The dealership is gonna look into adding LS in the rear end and get back to me.
EaTmYtAiLpIpEs
12-31-2021 07:30 PM
Liv4hockey
04-16-2019 04:27 AM
farm1966
01-25-2005 08:05 AM
gary7
01-07-2004 08:44 PM
Original Mr Plow
15
11-06-2002 06:33 PM
Quick Reply: Adding Limited Slip to 2011 Super Duty?
