blower motor upgrade
Old 06-15-2011, 06:46 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
so, i know we have tossed around the subject before... ive done a few searches on here and google but havent found anyone that did a different blower. theres people asking about any upgrade, people telling them to check their vent flaps but nobody with an actual swap. ive heard from you guys that you heard someone that did a crown vic blower. before i go and spend money id like to know what will work. i was lookin at my dads psd blower, looks pretty close. about the same size, ill have to wait til he goes outta town in my moms car so i can tear it apart and see if it will fit in my box lol. one guy said something about running a different relay. said having better voltage made a world of a difference in the speed. might hook up a 12v supply straight to it to see if that does anything. if not, ill look around for something else. any ideas would be good....
Old 06-15-2011, 07:10 PM
swooshcmk's Avatar
swooshcmk
swooshcmk is offline
Going for a stronger air flow from the a/c?
I just picked up a new replacement blower for mine because the blower was making more noise than my 4" straight piped engine! lol
Old 06-15-2011, 08:12 PM
kenpobuck's Avatar
kenpobuck
kenpobuck is offline
I have mine hooked up dicerct thru a toggle now and it made no diff in the speed. I think it was greystreak on in the big bronco furum that said something about the squirrel cage fans on newer trucks/cars being a better design.
Old 06-15-2011, 09:02 PM
oreocreaming
mine is new. the old one was crappy so i got this one from autozone when i got the truck. was exactly the same output
Old 06-15-2011, 09:07 PM
Lukes66's Avatar
Lukes66
Lukes66 is offline
The trick is to improve the ground to the blower. I have a ground wire going directly from my battery to my blower fan motor. That really made a world of difference in fan speed.
Next, I set up a relay with a big hot going straight to the battery to the fan. Everything works normally but I have a "turbo" fan toggle switch to throw the relay and run the fan directly off of the battery.
These 2 changes together, give fan speeds comparable to a modern vehicle. Maybe not quite as good, but I will put it this way, I stayed cool all day in it in 107 degree temps last week, and its a super cab with bad weather stripping.
Let me know if you want any specifics on this or have any questions.
The following 2 users liked this post by Lukes66:
Old 06-16-2011, 12:14 AM
Country_boy_2007's Avatar
Country_boy_2007
Country_boy_2007 is offline
roll the windows down..lol
Old 06-16-2011, 07:21 AM
ADTMan's Avatar
ADTMan
ADTMan is offline
RIGHT ON!!!!!!! LOL po po oreo.........
Old 06-16-2011, 08:15 AM
oreocreaming
How does that help when its 120 degrees outside?
Old 06-16-2011, 10:00 AM
Country_boy_2007
lol i couldent resist...thats what i do.
have you checked to see if your getting a full 14 volts (or whatever your truck charges at) to the blower when the truck is running?
Old 06-16-2011, 11:24 AM
bigschmadt00's Avatar
bigschmadt00
bigschmadt00 is offline
Trailering
I've got this on my list of wants. It wasn't so bad in southern Illinois, but in San Antonio, it's a good 30 minutes of highway driving to get the cabin temp to bareable. On high it blows about as hard as my 2010 Outback does on low. Well, maybe it blows that hard.
Old 06-16-2011, 09:37 PM
galute's Avatar
galute
galute is offline
I had the same problem with mine. Tried a couple different fan motors, neither helped much. One day I was messing around under the hood while it was running with the ac on high when I felt cold air blowing on the back of my hand. A closer look and I discovered my air box was leaking at the seams and about half my air was blowing out under the hood. Sealed up all the leaks and now my AC works great. Check for air leaks around the air box.
Old 06-17-2011, 12:48 AM
Country_boy_2007
i know its common for the damper to hang up and not close all the way, also check the foam seals like galute mentioned above
Old 06-28-2011, 11:01 PM
bghnkinf250's Avatar
bghnkinf250
bghnkinf250 is offline
I have to ask, how did you do that blower motor mod? I am very interested in this!
Old 06-29-2011, 12:33 AM
SnuffthePunkz's Avatar
SnuffthePunkz
SnuffthePunkz is offline
I'm a huge fan of the roll down the windows myself, much to the dismay of my passengers. I will admit in the year I've owned my truck, I've used the A/C twice. It was about 130, and I was towing a trailer during the summer, freaking broiling up that mountain road.
Old 06-29-2011, 09:58 AM
Country_boy_2007
i agree, i finally recharged mine, now i hardly use it
Quick Reply: blower motor upgrade
