1998 F150 won't start when it's hot....vapor lock? - Ford Truck Enthusiasts Forums
Old 06-15-2011, 05:22 PM
jehuie jehuie is offline
jehuie is starting off with a positive reputation.
This was happening last year and now that it's hot again it's driving me crazy once again. On hot days the truck will start and run a little bit rough for 10 or 15 seconds and then it's fine. But if I drive it a few miles and then stop, it won't start again no matter what I do. But if I let it cool down for an hour or so it will fire up again.
It only happens on hot days. And it's not consistent but it strands me somewhere at least a couple times a week now. I don't think fuel injection engines suffer from vapor lock do they? And it doesn't have an Ignition Control Module right? So what else could it be?
I've taken it to the shop twice and they haven't been able to help. Anyone? Please?!
Old 06-15-2011, 08:36 PM
Oh and I forgot to mention...I have replaced the thermostat and the fuel filter so those are out as potential causes.
Old 06-15-2011, 09:02 PM
blue2golf's Avatar
blue2golf blue2golf is offline
blue2golf is starting off with a positive reputation.
I'm having the exact same trouble with my '99 F150XL. I replaced the fuel pump relay, the fuel filter, tried opening the fuel cap to expel excess pressure and had it scanned by a local mechanic....no luck and my only code was the EGR causing the check engine light to come on.
However, I did ask the mechanic to check my fuel pressure. It was too low...fuel pump is going out. That might be the root cause. My mechanic could not be for sure that it would 100% fix the problem, but it probably would and that I need a new fuel pump anyway.
I'm buying a whole new sending unit tomorrow night and will install it this weekend. I'll update everybody on if this solution was effective or not.
Old 06-16-2011, 12:28 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Possible that one of these sensors has a plugup issue or sensor issue.
The Crank Position , the Cam position Sensor.
In the fuel circuit the pump relay and crash sensor.
EEC relay.
Loss of fuel pressure.
Check for codes and see if the PCM has been rebooted from power failure at any time.
When the problem is present you need to do the testing to find anything or it's just guessing.
Seem it's a heat soak issue as the engine bay gets hotter after shut down for at least 5 minutes due to the lack of fan cooling.
On my truck, I have a fan cooled aux transmission cooler with auto operation. In hot weather if the fan is not running it come on after I shut the motor off and runs for about 6-7 minutes before it shuts down.
The control sensor is sampling the trans inlet line at the radiator but still samples the engine bay as well so I get both functions from it set as about 185 to come on blowing air into the engine bay through the cooler and radiator.
Good luck
Old 06-19-2011, 10:38 AM
blue2golf's Avatar
Replaced the fuel pump yesterday. It hasn't been hot enough yet to see if this solves my problem. We've got some days forecasted in the 90s coming up. It shouldn't be too long of a wait.
'79 Bronco won't start when hot: SOLUTION! bryanmartin 1978 - 1996 Big Bronco 0 07-21-2015 04:48 PM
Hot engine, won't start stalls when slowing gobblerman 1961 - 1966 F-100 & Larger F-Series Trucks 23 10-06-2010 08:27 PM
1993 E150 vapor lock like problem banner1124 1968-2013 Full Size Vans 20 08-23-2006 01:13 AM
fuel pump? vapor lock? traderguy111 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 08-25-2004 10:48 PM
vapor lock or fuel pump traderguy111 Fuel Injection, Carburetion & Fuel System 1 08-23-2004 10:46 PM
Tags
1996, 1999, 2002, 2003, 2004, bronco, f150, ford, hot, ii, lock, ranger, start, v6, vapor, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
