AC not getting cold
Old 06-15-2011, 03:25 PM
HogTied's Avatar
HogTied
HogTied is offline
AC not getting cold
I have a 2008 F150 and previously owned a 2006 F150. Both had the 5.4 and both were similarly equipped. My AC in the 2008 absolutely sucks and the truck has only 29,000 miles on it. The ******* dealership told me the AC system in the 2007-2008 models are different than the 2004-2006 models. He said the 07-08 models inherently don't cool nearly as well as the 04-06 models did. Is that pure BS or is it fact?
My 2008's AC also stops blowing cold air on anything more than gradual acceleration. He said the 07-08's were designed to do this to send more power to the wheels. I call BS again.
Please chime in if you know anything about our trucks' ACs and whether my stealership's comments are fact or BS.
Old 06-15-2011, 03:46 PM
aquaman's Avatar
aquaman
aquaman is offline
My BS detector just pegged full scale and almost broke its needle!!
I see you're out in AR, so I don't know what it's like out there. I was going to say if your humidity is high, the A/C has a tougher job to 'cool' things down.
My '05 AC seems a bit weak. I topped off the freon a while ago, but it didn't seem to make much difference.. The biggest issue I have is there's some deal with my blend door not shutting off hot air completely. So with A/C off, it's always blowing warm air even if it's cold outside.
Last weekend, I 'rebooted' the temperature controller by unplugging power to the unit and then powered it back up. Same thing happens if the battery is disconnected for a while. You can hear the motor and doors moving around when power comes up again.
The jury is out to see if that makes any diff. Wife has been driving the truck, but she hasn't said/complained about anything yet...
Old 06-15-2011, 05:08 PM
HogTied's Avatar
HogTied
HogTied is offline
Any idea how to fix the blend door? I'm about to pick my truck up from the dealer and want to call them on their BS and mention the blend door.
Old 06-17-2011, 10:03 PM
krane operator's Avatar
krane operator
krane operator is offline
the only diffrence i know is the engine fan clutch on 07-08 is electronic controlled by pcm, but could still be faulty. I know in 06 there were some faulty fan clutches on the trucks. Mine was faulty the first day i drove my new truck home. My truck on a hot start up would not cool at all until on the road. Blend door could also be culprit.
Old 06-18-2011, 12:03 AM
dilas's Avatar
dilas
dilas is offline
I just got a 2007 F150 last week. I must admit that the AC is much better than my 2002 F150. Both have automatic climate control, the AC on old one was inconsistent. Doesn't always work, but seems to work better in cooler temps such as night time. On the newer truck, it blows cold air nicely even driving away from parked in hot sun during the day.
Based on my experience your dealer is likely BSing you.
Old 06-18-2011, 10:58 AM
j_blueridge's Avatar
j_blueridge
j_blueridge is offline
My 2007 A/C got a workout during 100 degree + nasty humidity in VA a week or so ago. It did as well as my old '90 F150 even though the cab is bigger.
Old 06-25-2011, 05:45 PM
fordsinair's Avatar
fordsinair
fordsinair is offline
The A/C on my '04 crew is weak too. Checked the system many times. I'be mentioned topping it off but adding to it would over pressurize the system. The air temp out of the vents is 48deg when we put a thermometer in it. But still, it doesn't cool well at all any time. There are many components to check and I hope to het it figured out.
Old 06-29-2011, 01:26 PM
Flippinstk's Avatar
Flippinstk
Flippinstk is offline
AC
I have a 08 FX4 and its AC is MUCH better than the 03 Expy that I had....
but I read a post on here a while back about a guy that was having AC issues and in the end he figured out that the heater control valve never completely closed, so there would always be hot water flowing thru your heater. Hense why there is always hot air coming from the heater... but its like that on all fords.... so to cure it he put a cutoff valve on his heater supply line and in the summer months just closed the valve. Wire tied it, just to ensure it either stayed closed or open... fixed the problem!
Old 06-30-2011, 03:02 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
Question
How is the fan clutch controlled by the PCM?
Old 06-30-2011, 07:03 PM
dos0711's Avatar
dos0711
dos0711 is offline
It's got an electric magnet
Old 06-30-2011, 09:38 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
One of the biggest complaints on my '07 was the AC. It never got as cold as it should have. I never pursued the problem and ended up trading it in, but yes, the AC was horrible.
The SD is much better but nothing holds a candle to my '99 Windstar. 215k and I've never had one issue with the AC. No recharge no nothing. I could probably chill a beer in there if I tried.
You might want to look into one of those heater core bypass kits. Might help.
Old 06-30-2011, 09:46 PM
BlueOvalFitter
Talking
Is that like the blinker fluid and muffler bearings?
Old 06-30-2011, 11:35 PM
2007F150FX4's Avatar
2007F150FX4
2007F150FX4 is offline
I'm not very happy with the a/c in my 07 either. I live in the Phoenix area and it gets hot, its been 105-110+ the last week or so.
It doesn't seem very efficient until you are at freeway speeds and even then it will take 15 minutes of driving to get to a comfortable temperature in the cab. When I am in stop and go traffic I get that humid feeling and wet smell in the cab. I also can hear the fan cycle on and off the slower I'm moving.
Its charged up. How does one test the operation of the PCM controlled fan clutch operation?
Old 07-02-2011, 01:59 PM
Steve Gray's Avatar
Steve Gray
Steve Gray is offline
I have A 2007 F150 4X4.The AC worked great when it worked.I'm in the process of replacing the clutch that has shorted blowing the fuse.Anybody out there ever replace one and what is the process.In other words how do you get to it.
Old 07-02-2011, 02:48 PM
j_blueridge
Electro-magnet? Like a solenoid maybe?
Quick Reply: AC not getting cold
