Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
Closed Thread
  #1 (permalink)
Old 03-26-2003, 08:32 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
Arrow Technical Information
Engine
Breaking in an Engine
Engine Rebuilding Advice
Flushing the Cooling System
2.3L Water Pump
3.0 Water Pump
2.3, 3.0, 4.0 Rear Main Seal Tool
-2.3L Timing Belt
2.3L PCV Location
4.0 SOHC Timing Chain Noise
Installing JBA Headers on a 1998 3.0
How to decarbon the 4.0 (Engine Knock)
Why use Double Platinum Plugs
3.0 Camshaft Sensor
4.0L Idle Air Control Valve
MAF Cleaning
O2 Testing
O2 Location
PCV Valve on the 2.3L?
Throttle Body Cleaning
-TPS Testing
-TFI-IV Ignition Troubleshooting
Ford DIS/EDIS "Waste Spark" Ignition System
Cold Air Intake for the 2001+ 2.3L
4.0L OHV Lower Intake Gasket Replacement
Diesel Ranger Information
-2.9L Cracked Head Replacement
Pics of Cracked 2.9 Heads
The Correct Oil for your Engine
Emisions
EEC Components and What They Do
-Pulling EEC IV Codes
More EEC-IV Codes
ODB-II Codes
DPFE Sensor Testing
More DPFE Sensor Testing
The EVAP System
The EGR System
Drive Train
-Tranny Ratios
Gear Calculator
-PCM Reprogramming for Tire Size and Axle Ratio Changes
Transer Case Low Ratios
About 2 wd Transfer Cases
Changing AFT Fluid
Tranny Fluid Change
Changing Fluid In M5OD 5 Speed Manual Transmission
-Leaking 5-speedManual -- Shift-Rail Plugs
-Fixing the Transfer Case
More on the Transfer Case
1993 4 Wheel Drive Modul-e Information
-1997 Auto Hub Repair
Slave Cylinder Bleeding
1998-2000 4x4 Pulse Vaccum Hubs
1998+ Driveline Clunk/Thump
Slip Yoke Lubrication
Welding Spinders
Building a 9” Rear
A4LD to FM146 Swap
Auto to Manual Hubs Swap on a 1989 Bronco II
Driveshaft Vibration Dampener
4R55E and 5R55E Transmission Valve Body Rebuild, Valve Body Gasket Repair
Brake and Suspension
-Pulling the RABS Code
-Pulling the RABS Codes for Older Trucks
Pulling ABS Codes for 1994
-Removing Front Rotor
-Front Disk Brakes
Warped Dsc Brake Rotor Myths
-Rear Drum Brakes
Lower Ball Joint Replacement
Dana 28 to Dana 35 Swap
Replacing shock absorbers
Rear and Front Diff's
Determining your gearing
See the next post in this thread for more links.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #2 (permalink)
Old 01-29-2006, 03:44 PM
Ken00's Avatar
Miscellaneous
FTE Tech Article Page
Acronym Definitions
GEM Information
Oil Pressure Gauge Conversion
1997 Ranger Instrument Panel Light Bulb Replacement
Details About the Ranger Sport Option
Installing Explorer Seats, Console and Overhead Console in a 1999 Ranger
Replacing the Plenum
Ranger & Explorer Fading/Blank Radio Display
1992 Radio Light Replacement
Radio Wiring Information
Dome or Door Ajar Light Stays On
Door Panel Removal
1989 Power Door Lock Wiring
Cruise Control Repair
1989 Cruise Control
Blend Door Fix
Charging A/C on a 1998 Style Ranger
Adding Foglights to 1998 Style Ranger
Bedliner Installation
Installing a Tonneau Cover
Fuel Pressure Testing
Fuel Sender/Pump Replacement
Changing the Fuel Filter on a 1999
Changing the Fuel Filter on a 2002
Door Sticker Decoder
Additives
FAQ about Gas
What Size Tire fit on a Ranger
What Size Tire Fit on a BII
Programing and Determining if You Have Keyless Entery
https://www.fleet.ford.com/maintenan...ls/default.asp
MultiMeter Guide
Paint Code Information
Truck Specifications
Disconnecting the DRL System
Part Number for 1998-2003 Tow Hooks
How to Replace your Headliner
The 3.0 Technical Information Page
Shift-on-the-Fly 4WD Switch Motor Rebuild
Please email me if you have something to add to this thread.
FTE is not responsible for the content of these links.
__________________
Ken
  #3 (permalink)
Old 08-29-2006, 02:34 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
fte automotive calculators
FTE now has a automotive calculator page figured this was a good place for the link
CALCULATORS
__________________
Rob
Dying's not so bad
It's living that will kill you off
  #4 (permalink)
Old 11-19-2006, 09:51 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
Moderators please do not add nor subtract from this stickie at all, if you need to..... Contact me.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #5 (permalink)
Old 03-06-2007, 10:35 PM
4r55e 5r55e Ranger / Explorer Transmission Problems
http://www.ford-trucks.com/article/i...dy_Gasket.html
__________________
Rob
Dying's not so bad
  #6 (permalink)
Old 03-09-2007, 09:01 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
5r55e / 4r44e Transmission fix discussion
http://www.ford-trucks.com/forums/58...lick-here.html
Lift options for Rangers
Lift Options for 2001+ Rangers
Save Those Auto Hubs--Easy Fix With Pictures
http://www.ford-trucks.com/forums/45...-pictures.html
Fix Ford Radio Illumination Bulb
http://www.ford-trucks.com/forums/sh...80&postcount=1
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #7 (permalink)
Old 01-04-2009, 12:33 AM
fordboy_52's Avatar
Replace window regulators
http://www.ford-trucks.com/forums/80...egulators.html
Flush and clean auto tranny
http://www.ford-trucks.com/forums/652748-full-tranny-fluid-pump-out.html
__________________
  #8 (permalink)
Old 05-03-2009, 09:27 PM
fordboy_52's Avatar
Ranger tranny fluid pump out / change
http://www.ford-trucks.com/forums/65...-pump-out.html
Ranger 4x2 Ball joints
http://www.ford-trucks.com/forums/68...ll-joints.html
__________________
Closed Thread
Tags
1997 , 2001 , 23 , 40idle , air , camshaft , control , ford , information , location , pump , ranger , removal , sensor , technical , valve , water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
