Biodiesel in a 6.0L - Page 2 - Ford Truck Enthusiasts Forums
Biodiesel in a 6.0L
Old 06-28-2011, 07:58 PM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Quote:
Originally Posted by MATHSECRET View Post
You guys are great! I was thinking my question will be unanswered...
Clean bio in my area does not offer a big saving ($4.10 compared to $4.13) and it is a little out of the way to fetch. I had found BioFuelsTechnologies.com that has a waste vegi fuel kit for excursions, cost about $5k (with seperate tank, plus installations.)
I had also talked to Roy of BioFuelsTechnologies.com, these guys are awesome as well. Their solution seem to be the fix. (at about $5k total, i can run on any bio, savings should be realized after 30,000 miles. Maybe 40,000 miles considering I have to setup my own filteration system to filter out the eggrolls and chimichangas) Still need to solve the issue of getting my neighbors to okay the unsightly tanks in my backyard.
Anyone got any new thinking or advice?
Just to clarify, biodiesel is not the same thing as vegetable oil/SVO. With biodiesel, you can run it in your Excursion with no modifications.
SVO (straight vegetable oil), set up properly, requires modifications to your Excursion, i.e. heat, valves for switching fuels, etc.
If you make frequent short trips of say 15-20 miles or less, SVO might not be a good option. (You need to start out on pump #2 before switching over to veg oil, and then you have to factor time to purge with pump #2 before shutting down.)
Old 08-06-2011, 08:21 PM
mah77's Avatar
mah77 mah77 is offline
mah77 is starting off with a positive reputation.
Ive read that Ford only "recommends" running up to B5 in the 6.0. Ive also read on other forums that running bio in a 6.0 will cause your injectors to fail sooner. Is there any truth or validity to this?
I have an '06 6.0 with 32k on the clock. Propel just opened a station near my house that offers B20. Im on my first tank of bio (B5), and havent noticed a difference in anything. Am I safe stepping up to B20 with the modifications listed in my sig?
Also, is it pointless to continue running Opti-Lube XPD when stepping up to bio?
Old 08-07-2011, 03:24 PM
Fett Affen's Avatar
Fett Affen Fett Affen is offline
Fett Affen is starting off with a positive reputation.
B100 in a 6.0
I have been running B100 in my 04 for 60,000 miles now and have not had a problem with it. It runs smoother, quieter, and doesn't smell like the acidic dino fuel. I had a chance to put the truck on a dyno to check power on both dino and then bio, actually was a bit of a disappointment as the bio showed a 30% drop in h.p. and torque. However the mileage has gone up about a mile and a half. When my friend on the dino tried to make me feel bad about the drop in power I just asked him how much he pays, he never said another word. If I need to haul my dump trailer, then I just mix 50/50 with dino and my power is back. I make my own and have learned a lot on this forum and I would urge you to look into the same. It's not incredibly difficult if you are mechanically inclined and just pay attention to safety.
Old 02-28-2012, 11:45 AM
emsbull's Avatar
emsbull emsbull is offline
emsbull is starting off with a positive reputation.
Thanks everyone for the information. I have run B100 in all my farm equipment and have never had any issues and I like the smell with no worries of spillage in my pastures. I was very uneasy on using this in my 05 6.0 but reading through here has given me a great peice of mind. I will head that direction as weather warms and provide some feed back.
Old 02-29-2012, 01:55 PM
dullchrome dullchrome is offline
dullchrome is starting off with a positive reputation.
Does anyone know of a bio diesel location in or near Orange County(Huntington Beach) Ca? I have been thinking about switching over to bio on my 07 6.0 but cant seem to find anywhere that sells it locally.
Old 02-29-2012, 02:12 PM
binuya's Avatar
Quote:
Originally Posted by dullchrome View Post
Does anyone know of a bio diesel location in or near Orange County Ca? I have been thinking about switching over to bio on my 07 6.0 but cant seem to find anywhere that sells it locally.
Here's one in Corona: Biodiesel.org - Retail Fueling Sites
Old 02-29-2012, 02:17 PM
Old 03-01-2012, 11:48 PM
ATV PRO #11's Avatar
ATV PRO #11 ATV PRO #11 is offline
ATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to behold
Quote:
Yep, save your $$$ 5% blend of Bio increases lubricity 62%. At least with Canola as the feedstock, not sure of Soy, tallow, WVO ect.
2004 6.0 and Bio? Hotwheelbill Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 01-08-2014 11:56 PM
6.4 on Bio-diesel DynamoDale Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 02-29-2012 11:00 PM
Bio Diesel Concerns John with beastly 302 Bio-diesel, Propane & Alternative Diesel Engine Fuels 9 03-20-2008 06:02 PM
Bio-Diesel Question horser72 Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 03-07-2008 09:55 PM
bio?.... slowmans Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 11-05-2007 11:21 AM
Tags
60, 60l, bio, biodeisel, biodiesel, diesel, engine, filter, ford, fuel, harm, problems, put, run, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
