Truck shuts down while driving then show "low oil" warning - Ford Truck Enthusiasts Forums
Old 06-15-2011, 10:38 AM
rcklnhunter rcklnhunter is offline
rcklnhunter is starting off with a positive reputation.
My truck is still fairly new with 4,600 miles. I took my family on a camping trip and pulled my trailer which is about 7800 LBS. I made multiple hill climbs and mentioned to my wife how well the truck does on the hills pulling the trailer then a minute later the truck jolts and a "low oil" warning light flashed on the dash. By that time the truck had already shut down and I was coasting to the side of the road. At least I still had the ability to steer until I hit about 2 mph then the truck completely shut down. I could smell burning oil or something similar coming from the engine area.
I knew I had plenty of oil because I had just checked it hours before. I got out and checked it again and was still full. After standing there for several minutes starring at the truck I realized that our big yearly trip up North to the redwoods was over. I tried to start the truck again and it just turned over but wouldn't start. Nothing was smoking or appeared to be leaking. So I started to look for the Ford tow truck number. While looking for the number I tried to start it again and it started! I drove it about 3 minutes down the road to a gas station and called the dealer. They of course said never heard of the issue. Have the truck and trailer towed in to the nearest dealer. Well decided I wasn't going to do it since I was already in the middle of no where and the truck was driving fine. I wasn't going to ruin our big trip over this so I drove it. I figured if something failed at least they could fix it and not tell me they can't duplicate the issue after 3 days. The truck drove fine the rest of the way there.
It happened again coming home. While climbing another hill in the middle of a 2 lane canyon with no shoulder and no cell service. Luckily, I coasted a few hundred yards to the only turn out I saw in a mile stretch. Once, again it showed "Low oil". I let the truck sit for 5 minutes and it started. Drove it another 5 hours home with no issues. I monitored all my gauges during this time none showed over heating.
So in summary, truck shows "low oil" warning then shuts down and restarts minutes later. Has anyone seen this issue before? I will be taking it in to the dealer soon but I'm expecting the standard can't duplicate the problem. In the meantime I am just hoping someone on this forum has had this issue and found the problem which can speed up the diagnosis. Thanks for your help on this long story!
Old 06-15-2011, 11:16 AM
Biggziff's Avatar
Biggziff Biggziff is offline
Biggziff is gaining momentum as a positive member of FTE.Biggziff is gaining momentum as a positive member of FTE.
I haven't read of this being reported on the 6.7 yet, but it doesn't mean someone hasn't had the issue and doesn't use the interwebz....
I'd like to think it's a bad sensor.
Old 06-15-2011, 11:37 AM
buckmasters's Avatar
buckmasters buckmasters is offline
buckmasters is starting off with a positive reputation.
It could be any number of things that affect the pressure or amount of oil being circulated through the engine (pump, filter, sump, etc) or simply a bad sensor. I have no idea what the burning smell could be.
My wife had this type of issue after getting an oil pan replaced on her vehicle and then a low oil pressure light came on. It is a Honda and silicone is used to put the new oil pan back in. Some of that silicone leaked into the pan and got sucked up/clogged in the sump. At 4,600 miles, I'm guessing you haven't done an oil change (so no way for debris to get into the system unless it's engine pieces). That would rule out the sump and filter (unless the filter got damaged under the truck). I would get under the truck and make sure the filter looks to be in good shape with no damage, leakage, or cross-threading.
Old 06-15-2011, 02:29 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Sounds like going up a long hill the oil isn't draining back into the sump,
thus it sucks air and the engine stalls. low oil could mean either
the engine has stopped and thus low oil pressure, or low oil level.
After 5 minutes enough oil is back in the sump for it to start.
Maybe a clogged oil filter?
You are close enough you might have the 1st oil/filter change
and maybe it'll go away?
good luck!
Old 06-15-2011, 07:13 PM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
Wouldn't it be a good idea to change the oil sooner than the reccomended "5000" miles the first time? All the engine parts are new and wearing together. My dealer told me it shouldn't need an oil change until the reccomended interval, but I am not completely sold on that theory. I'm not saying this would be the cause for the engine shutting down, that does sound fishy. I'd be curious as to what it is. I also hope the engine isn't hurt in any way while operating under those abnormal circumstances.
Old 06-15-2011, 08:12 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Hi Steve,
The early break-in oil change has been proven pretty well to be unnecessary on modern engines; I've never heard of anyone who's had any engine trouble that could be reasonably attributed to failure to change the oil early.
Have you been to - Bob is the Oil Guy It's a great oil forum, and they debunk lots of common myths.
Old 06-18-2011, 08:41 PM
lakedweller's Avatar
lakedweller lakedweller is offline
lakedweller is starting off with a positive reputation.
I thought the first oil change was at 10,000 not 5,000. I'll have to check my book and see.....
Old 06-18-2011, 08:45 PM
Tom's Avatar
Quote:
The recommended first oil change is whenever the OLM dictates; there is no set specification. For most it's between 6-8,000 miles.
Old 06-19-2011, 12:58 AM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Yes, the manual says to follow the IOLM.
I change within the 5k range but if I don't reset the computer, it makes it a few hundred past 7,000 before alerting.
Old 06-19-2011, 02:10 AM
mikespecht mikespecht is offline
mikespecht is starting off with a positive reputation.
im going to go with the OLM for mine, seems like they have put a lot of thought into it. i will keep an eye on how many miles i have driven since the change and if i am getting high and the system doesnt tell me to change, then i may just go by how far i have driven. but untill the OLM lets me down, or i hear of others having problems because of it, i will change the oil when it tells me to
Old 06-19-2011, 01:27 PM
Took the truck in a few days ago and had it hooked up to see if there was a code to retrieve. Of course no luck. So they were going to talk to their reps and see if they can come up with some ideas. So far I have not heard anything yet. I'm hoping they will just start making some guesses and replace something to see if it works. Somethings got to be done because it was pretty dangerous and blind corners when your truck dies. I'll keep everyone updated. Maybe someone from Ford will read this and offer some help.
Old 07-17-2011, 08:51 PM
ler8823 ler8823 is offline
ler8823 is starting off with a positive reputation.
This exact same thing just happened to me while towing on a family trip. I pulled over and about 60 seconds it restarted never did it again. Have you found anything out about it....
Old 07-18-2011, 08:40 AM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant future
we need to figure out, was this a low pressure message or a low level.(is the truck even able to monitor oil level) once that has been clarified then a tech can start looking at sensors,wiring, or if the message is legitimate. the fact that no codes were found tends to lean towards it not being an actual mechanical problem, but it does need to be addressed so you you can trust and enjoy the truck safely
Old 07-18-2011, 11:08 AM
jermort's Avatar
jermort jermort is offline
jermort is starting off with a positive reputation.
Just guessing here, but I'd be willing to bet that the low oil pressure warning is due to the fact that the motor shut down and is not making any oil pressure. The two may not be related at all.
My 6.7 will display the low oil pressure warning if I key on, but I don't start it within a few seconds.
Many of us have experienced 'anomalies'. Not saying that is what happened to you. I had a short 10 mile drive where the boost gauge read '0'. Clearly, I had no boost, no power. On restart, everything was normal, has never happened again. 23.5K miles.
just my .02
jammer
Old 07-18-2011, 09:09 PM
kper05's Avatar
My low oil pressure light would turn on prior to starting (KOEO) only sometimes.
(Thank you truck computer; of course there is low oil pressure.)
It actually hasn't happened in several months now that I think about it.
If it was consistant that's one thing but it wasn't.
I would cycle the key and everything would be normal for another 2-3 weeks; sometimes less, sometimes more.
Transmission Overheated :( Christopher Dickson 1999 to 2016 Super Duty 7 11-02-2016 01:56 PM
Fuel Pump Just Died AGAIN after 1500 miles, waiting for tow Mystic_Cobra 6.7L Power Stroke Diesel 56 09-09-2016 11:28 AM
Dies hot, no start for 10 minutes TDIDog 6.0L Power Stroke Diesel 21 04-14-2016 04:36 AM
Low Oil Pressure Derrrrick 1987 - 1996 F150 & Larger F-Series Trucks 9 10-22-2015 11:46 PM
99 E350 with 7.3 issues mikefred44 1999 - 2003 7.3L Power Stroke Diesel 3 06-01-2015 11:10 AM
Tags
2002, car, cuts, diesel, driving, f350, ford, good, low, off, oil, road, running, shut, shuts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
