Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-15-2011, 08:14 AM
speedtrash speedtrash is offline
Garage is empty, add now
speedtrash is starting off with a positive reputation.
engine knock on startup
i have a 2007 expedition i bought new it has a 100K warrenty on it.
it stared to make a knock on startup that has gotten progressevly worse over time. the dealer installed new timing chanis and this did not help. it sounds like a rod or heavy detonation. it does not do it all he time. the dealer is blowing me off and saying he does not hear it. i have seen posts about cam phasers and piston slap and that if you complain enough they will replac the engine. need help
  #2 (permalink)
Old 06-15-2011, 11:10 AM
berry1234's Avatar
berry1234 berry1234 is online now
berry1234 is gaining momentum as a positive member of FTE.
I had a tapping that just never went away at 10K miles, ended up replacing one of the heads. THen at 50K or so I got a marble sounding rattle on start up. It ended up being the timing chain tensioner gaskets and tensioner arms worn out. After they replaced that its fine.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Tags
351m, 49, chain, engine, expedition, ford, guides, knock, knocking, light, lincoln, navigator, phaserstension, start, startup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
