Need some EFI 5.0L help
Got an 88 Mercury Grand Marquis with an EFI 302. When you let off the accelerator (coasting to a stop and such) it dies.
The codes i got:
KOEO:54- Mid temperature switch is open constantly
82- Air diverter solenoid circuit fault
KOER: 91- O2 sensor always lean
I have no idea what the two KOEO codes mean. I'm sure it needs a tuneup, but could that be all that it needs?
Help please....this is my sisters car...
The codes i got:
Air diverter solenoid could be "Stuck" open and allowing for fresh air to be continously pumped into the exhaust giving you the "O2 Always Lean". I have had several problems in the past and I ended up getting both the Thermactor Air Diverter and Air Bypass solenoids from my the Dealer.
If you do a search for those terms, TAD, TAB, Thermactor, you will find more info. I know RLA2005, Subford and myself have covered this.
Hope this helps.
Hope this helps.
grldben
08-04-2013 08:45 PM
texasyakfisher71
08-03-2010 01:30 PM
