how do i getmost mpg
#32
#33
easy , drive barefoot with tacks on the loud pedal
most i ever had was 16.4 ish in my 6.8 driving like my grt grt grandfather
for about 800 mile round trip.
unless you count the downhill bits where i take my foot off the gas, press the reset button and tell the wife 'this really is an economical vehicle' as it shows 30+ mpg for a while lol
the 6.8 was never built for MPG imo.
#35
#36
#39
Oh yeah, contrary to popular belief the brake pedal wastes more gas than the accelerator. It is not how fast you accelerate it is how often you use the brakes. Anytime you stop the vehicle or slow it down you have to make that momentum back up which takes energy=gas. That is why hybrids do so well around town is because they use that braking energy to charge the batteries. So slow down before you get to stop lights so you don't waste so much energy. Try to coast before you stop. I have found that occasional full throttle operation during passing does not seem to hurt gas miliage very much because I don't slam on my brakes when I get around the guy. I just let it coast back down.
Overall speed kills gas miliage and that is because the drag force a function of the velocity squared. So you double your speed your drag increase by a factor of 4X. When you are pushing something shaped like a brick it adds up fast.
Perry
Perry
#42
I added a 5-star tuner and Y-pipe conversion from 5-star 2 months ago and really saw no mileage gain whatsoever (hand calc) from stock, even with the "economy" tune.
It sounds a little better and I see a bit more power right off idle, similiar to back in the '90's when we'd advance the timing on our 5.0 mustangs.
I think the biggest factor in gas mileage with these things is to learn to use momentum and moderate your speed. The truck weighs 3.5 tons, getting it started or back up to speed uses a LOT of gas. But, it'll coast forever. Look farther ahead since you're up high; if you see a red light coast well in advance and you might not have to come to a stop at the light, use less gas to get back up to speed.
Use your cruise control!!
As others have mentioned, this thing does use a lot of gas at idle as well.
-T
-T
#43
Here is one of my old post!
This is one of my old post.... please excuse the caps, u all ripped my emails *** to calm it down..... lol
I HAVE TRIED THE E3 SPARK PLUGS ABOUT 2 YEARS AGO. IT DID NOTHING FOR ME IT PROB WASTE MORE GAS, THEY BURNED MY FUEL INJECTOR IN MY FUEL SAVIN CAR.
I THINK THEY ARE CRAP.
I HAVE REPLACED A LOT OF MY STUFF:
I HAVE REPLACED MY MASS AIRFLOW SENSOR WITHS JETS
GOT JETS SPACER (GOOD BY CRUISE) UNLESS U HAVE AN EXTENTION
BBK DUAL 65MM THROTTLE..... HOLD ON TO YOUR BUTS
ROYAL PURPLE DOES THE JOB FOR BETTER FUEL ECOM. I REPLACED MY TRANSMISSION ENGINE AND DIFFS WITH ROYAL PURPLE..... WOW SMOOTH!
K&N AIR INTAKE PRETTY COOK WITH THE BBK... (U CAN HERE THE AIR SUCK RIGHT INTO THE ENGINE WHEN UR UNDER THE HOOD.
TAKE OUT THE THIRDROWSEAT. TOOK OFF THE RACKS UP TOP. BYE BYE SPEAR TIRE. TOOK OUT THE TIRE JACK AND RATCHET OUT UNDER HOOD, THE STEPS
REDUCE WEIGHT EVERYWHERE I CAN
NEXT UP AN ELECTRIC FAN AND FREEING UP THE Y PIPE AND SGT CHIP AND BANKS POWER PACK AND CHANGING THE COILS NOW!
UMM! I AM SURE THERE IS MORE!!
HIT ME UP!
TORNADOS AND HYPERTECH MPG AND E3 PLUGS SUCKS REALLY BAD ....
I DO HAVE THE FITCH FUEL INSTALLED.... I DONT KNOW IF IT WORKS BUT I THINK I AM DOING BETTER.. (I DID A LOT OF THESE UPGRADES AT ONCE.)
MY SPARKS ARE DOING OK THERER THE BOSCH +4 NOT BAD BUT WILL CHANGE THEM SOON BACK TO AUTOLIGHT OR MOTORCRAFT!
AND I AM GETTING AOUND 11.6MPG 40% CITY 60% HWY
6.8L V10 EXCURSION
HIT ME UP!
6.8L V10 EXCURSION
#44
You got that right... I get 13 on the highway at 70mph with the cruise on. I have new plugs, K+N air filter, tires aired up to almost max.... no way to get decent mileage out of a V-10 unless you turn the truck off and coast down hill
#45
