Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 06-14-2011, 06:25 PM
mattdogg02 mattdogg02 is offline
Garage is empty, add now
mattdogg02 is starting off with a positive reputation.
A/C not cold during idle, after broken belt
First want to say, I searched and didn't really find anything specific to my problem. Here is the issue. Had the belt break... while replacing it, noticed the wiring that is connected between the pulleys and the fan had been knocked out of its holder (assuming this is some kind of fan clutch engager??), I believe by the broken belt pieces "flapping" around. I got it back into place, didn't notice anything disconnected, and got the new belt in place. Didn't notice it the first time driving as it was already a little cooler out and didn't really idle on my way home. I guess the next time driving we noticed that it wouldn't get cool when stopped and idling, and since it was 100 degrees outside it was pretty bad (not quite a hair dryer, but definitely warm air blowing). I washed out the radiators to ensure there wasn't a build up of dirt, and checked the compressor, which would turn on... run for about 20 seconds, cut off for 20 seconds, and continue this cycle. The fan seemed to run about the same as idle speed (is that normal, or should it speed up?). My thoughts are that the fan clutch isn't engaging properly (by getting whacked by the belt?_, and the fan isn't cooling the condenser correctly, but while driving that isn't an issue? Or could I just have a leak? By the way, this is a 2007 Expedition with ~70k miles. A/C works great when normal driving and worked fine before this. Any help is appreciated, Thanks!
  #2 (permalink)
Old 06-15-2011, 10:35 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Sounds like it is low on Freon. Don't let it cycle too much like that or you might be replacing the compressor.
__________________
See ya,
Eric
Tags
60, ac, air, conditioning, cool, cooling, econoline, expedition, ford, freestyle, idel, idle, idling, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
