Wiper fluid wont pump? - Ford Truck Enthusiasts Forums
Old 06-14-2011, 04:48 PM
Ford4Life7.3's Avatar
Ford4Life7.3 Ford4Life7.3 is offline
Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.
Alright, first post on this forum! So far ive found all i need from others, but here we go. The wipers and everytrhing work, but when i push the wiper button for the washer fluid, it wont pump. I checked to see it was full, and the line is attatched. I felt along the line, and didnt feel anything in it that would block it off. Does anyone know how it pumps, or what it uses to pump, as well as what else to check.
Old 06-14-2011, 10:28 PM
tecgod13 tecgod13 is online now
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
There should be a pump that pumps the fluid from the tank to the nozzles. I can't remember where the pump is, if its on the tank, or separate, but if you look at the tank and follow the lines from the nozzles you can figure it out.
Once you do, pull of the electrical connection and see if its corroded. If you have a voltmeter or test light, have someone hold down the washer fluid button and see if you get voltage at the connection. If you get voltage, but no fluid, might have to replace the pump.
Last thought, these aren't like newer vehicles where you hit the button, it sprays for a couple seconds and the wipers do a few cycles. You may have to hold the button down for a few seconds before anything comes out, and turn the wipers on manually.
Old 06-14-2011, 10:52 PM
Thats what i thought, but there is no pump along the line anywhere. The ruber tube goes directly from the washer fluid box to the little **** where the fluid sprays on the windhseild.
Old 06-14-2011, 10:54 PM
How do you put a picture into a reply btw, i took one so i can show what the setup looks like.
Old 06-15-2011, 05:14 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
if i remember correctly, the pump in in the bottom of the fluid reservoir.
Old 06-15-2011, 07:24 AM
NorthernDiesel's Avatar
NorthernDiesel NorthernDiesel is offline
NorthernDiesel is starting off with a positive reputation.
Yea its in the bottom of the tank. Check the bottom of the tank where the hose runs from, there should be wires coming out of the pump. Pull the wiring connector off and there will be a thin spingy steel ring with little tabs all around it. Pop the ring out with a pick or pliers (you'll probably damage it, but a new one comes with the new 20$ washer pump) and the pump pulls out the end.
Before pulling out the pump, you might want to check voltage in that connector while trying to spray to make sure it is the pump. That little tab ring never goes back in as well as it does the first time, so replace it if you pull the pump.
Old 06-15-2011, 11:56 AM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
I had a simular problem a few weeks ago. The pump just stopped pumping. Yes the pump is in the bottom of the ww fluid tank literally. I removed my pump, can't remember how but it wasn't hard to do. I plugged it in and nothing. I started moving the pump mechinism till it was free moving. I reinstalled it and have had no problem since then.
Windshield wipers not working Borgia 1999 to 2016 Super Duty 1 10-23-2016 11:11 AM
What the hell is going on with my wipers... RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 3 10-04-2015 12:44 PM
Windshield wipers and washer fluid not working vee-eight-fords 1999 to 2016 Super Duty 12 06-11-2011 12:14 PM
did my water meth kit rideracelivemx7 1994.5 - 1997 7.3L Power Stroke Diesel 18 05-19-2011 08:55 PM
Please HELP!! Wipers not working caseymike143 1999 to 2016 Super Duty 1 03-23-2011 07:34 PM
Tags
2002, 2003, 250, 350, connector, edge, f150, f250, fluid, ford, motor, pump, taurus, washer, wiper, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
