Which Programmer is Best for 6.4L - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 06-14-2011, 04:10 PM
20086.6xllongbed 20086.6xllongbed is offline
20086.6xllongbed is starting off with a positive reputation.
Hello Folks,
I am looking for a Programmer for my Truck, 2008, 6.4L, XL, 4x4, Longbed, Superduty Crewcab. I'm Not looking for Serious Power, This truck is a daily driver, i pull a 29' camp trailer, a 3 cord wood trailer, and live in the mountains of Oregon, I have a AFE Stage II air cleaner. Im not looking to do serious work but im just trying to get advice as to what upgrades, i need and which work best and which arent really needed. Any Help will work.
Thanks
-Rick
Old 06-14-2011, 06:48 PM
Brandon D's Avatar
Brandon D Brandon D is offline
Lead Foot User
Brandon D is gaining momentum as a positive member of FTE.Brandon D is gaining momentum as a positive member of FTE.
Opinions vary greatly on tuners, so do a quick search on this site and you can read all the info you'll ever need on which tuner to buy and why. I highly recommend Spartan but others have had luck with different systems. It will all come down to personal preference in what you're looking for (ie dpf on tunes/shift on the fly etc) and what your budget is. Other than tuning most of the mods are personal preference, anything that can be done to lower EGT's is a benefit to this motor as well as ditching the DPF (which it sounds like you're about to!). Best advice most will give is to be diligent with maintenance and work the truck like it was built for. Good Luck
Old 06-14-2011, 07:36 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I run the banks 6-gun on mine. That is a DPF on tuner...
So there are two choices and there are many more.
Old 06-14-2011, 08:27 PM
bushman134 bushman134 is offline
bushman134 is starting off with a positive reputation.
I use an H&S XRT pro and am very satisfied with the power and mileage. It will DPF on or off. I have both the DPF and the DOC deleted. Best thing is all tunes are free
Old 06-14-2011, 08:32 PM
longview1's Avatar
longview1 longview1 is offline
longview1 is gaining momentum as a positive member of FTE.
Quote:
I use Spartan, also does dpf on/off (not shift on the fly). Also they have frequent updates which are free!
Old 06-14-2011, 08:46 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
Im running a SCT Livewire witrh custom tunes from eric at Innovative Diesel, truck runs great, also running a afe stage II dry, DPF delete pipe and a spartan cold side pipe. I dont think you will be disappointed any way you go, but I have heard nothing but great things about Innovative on multiple forums and thats what helped me decide!
Old 06-15-2011, 11:41 AM
alexk41 alexk41 is offline
alexk41 is starting off with a positive reputation.
All things aside. i would go with a H&S tuner. beautiful screen and switch on the fly. i run one with a 300 horse tune and dynoed at 590 with Bullydog intake H&S tuner and DPF delete. H&S would be my first choice.
Old 06-15-2011, 01:43 PM
Ronin 5729's Avatar
Ronin 5729 Ronin 5729 is offline
Ronin 5729 is gaining momentum as a positive member of FTE.
^^^ What they all said!
Your first real decision is whether or not you're going to delete the DPF. After you make that decision then you can start narrowing down exactly what you're looking for in a tuner, just avoid the canned garbage (Superchips, etc.)...
Best Programmer 2000 7.3 Powerstroke?! Nabors 1999 - 2003 7.3L Power Stroke Diesel 135 04-03-2013 09:32 AM
Best Digital Gauges? BigSilly86 6.4L Power Stroke Diesel 1 11-02-2011 09:41 AM
Anyone have exp. with Hypertech 42000 programmer? CALIF-F250MAN Modular V8 (4.6L, 5.4L) 5 11-09-2010 06:52 PM
6.4L F-350 looking for fuel help Glen Willard 6.4L Power Stroke Diesel 33 03-02-2010 08:37 AM
New 2009 F350.... Which Programmer/Chip?????? SamDeMan 1999 to 2016 Super Duty 2 10-17-2009 02:02 PM
Tags
03, 2008, 64, 64l, air, diesel, explorer, f250, filter, ford, hs, programers, programmer, trans, truck, twix, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
