Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-14-2011, 10:28 AM
jpayne10 jpayne10 is offline
1988 Ford F-250
jpayne10 is starting off with a positive reputation.
1988 F250 Wiring
Well my trucks wiring under the hood looks like a rats nest. i was wondering what years & models i could nab a desecent one from in a local junkyard.
1988
F250
351W
A/C
4x4
Std cab.
Also, do these have an under hood fuse box or something because i have yet to find anything like it. im assuming it may have been removed in place of the rat's nest on the driver side inner fender
  #2 (permalink)
Old 06-14-2011, 11:11 AM
nstueve's Avatar
nstueve nstueve is offline
1988 Ford F-250
My Garage
nstueve has a very good reputation on FTE.nstueve has a very good reputation on FTE.nstueve has a very good reputation on FTE.nstueve has a very good reputation on FTE.
welcome to FTE... Depending on what wiring you lost to the mice/rats you can probably be safe pulling a harness from another 87/88-90 EFI 302 or 351w with XL or XLT package b/c it has the AC wires for the compressor. Keep in mind EFI was new in 87-88 so the wiring for the SD EFI systems weren't integrated into the truck harness fully until 89-90...
__________________
Thumper 88 F250 ZF 4x4 4.9L 3G 238K-main work horse
Zeus 89 F250 ZF 4x4 351w 143K- tow rig project
Ol' Girl 83 F150 NP208 300 T18 358K Offy DP 4bbl Holley
Did I say somthing GOOD? Click MY HEART!
Nathan - FTE Iowa Chapter
  #3 (permalink)
Old 06-14-2011, 12:11 PM
1988 Ford F-250
wasent lost to mice was rewired by a 3 year old by the looks
i found a 91 donor today, any good with that one?
  #4 (permalink)
Old 06-14-2011, 01:36 PM
nstueve's Avatar
1988 Ford F-250
My Garage
the 302 and 351w are the only 2 motors you can barrow from and you'll need a SD truck from 88-91... Like i said the bundling of the wires might be a little different but it will certainly do the job!
__________________
  #5 (permalink)
Old 07-03-2011, 06:12 PM
ps71mustanger ps71mustanger is offline
Garage is empty, add now
ps71mustanger is starting off with a positive reputation.
1988 F150 to 1990 F250 Transm./transfer case wire hookup
I am trying to transfer a 88 F150 wiring and fuel system onto a 1990 F250 4X4 chasis and drive train with a 5 speed stick which was wrecked. I am also transfering the 4.9L out of the F150 to replace the 351W in the F250. Everything seems to match up except some of the wiring. I am trying to find the electrical wire that will attach the tranny and transfer case to the wiring harness of my 88's 150 2wd wiring harness. The hookups are not the same as on the 90's 4X4 wiring harness connections with the 351W. The wire operates the backup lights and dash lights when it is in 4 wheel drive. Do you know what will work?
  #6 (permalink)
Old 07-05-2011, 09:28 AM
nstueve's Avatar
1988 Ford F-250
My Garage
I'm not sure I follow what you are trying to do... IS there 3 trucks? how are they set up? what are you trying to rob from one to make the other work? be a little more clear about what you are trying to do/accomplish... Please...
I don't have the oem wiring pics here at work... You'll need the wiring diagrams for all 3? trucks so you can match the wires... Or you'll have to power the wires with 12v current to find the back up light wire. Or if someone else on here understands what is going on better than I and have the right diagrams????
__________________
  #7 (permalink)
Old 07-06-2011, 10:01 PM
Transfer 1988 F150 to 1990 F250 4X4
Sorry I didn't get back on this sooner.
I have 2 trucks. A 1988 F150 2wd with a 4.9L 5speed stick. The other truck is a 1990 F250 4X4 with a 351W 5speed stick. (Or 4 speed w/overdrive)
I am wanting to transfer the body of the 1988 F150 onto the frame and drive train of the F250. I have already removed the body off the F250 as it was wrecked in the drivers side and had major rust and has been scrapped.
I am also transfering all the wiring, fuel tanks and lines from the F150. I am also removing the 351W and putting the inline 6 in it's place.
So basically it will be my 1988 truck on a 1990 frame and drive train.
Everything should change over just fine. The only thing that I don't know about is the wiring that connects the transmission and transfer case to the main wiring harness. (for the back up lights and 4X4 dash lights I presume)
The F250 has 2 connectors to the main wiring harness from the transmission and transfer case, but they are not the same type of connector as the F150.
On the F150, it has only a single connector from the transmission. I cannot find another open connector for the transfer case unless it was set up differently for that year and has only one connector.
I don't know if a 1988 F150 4X4 from a junk yard would have the connecting wire that I am looking.
Do you understand what I am asking ?
  #8 (permalink)
Old 07-07-2011, 03:59 AM
tjc transport's Avatar
tjc transport tjc transport is online now
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
you will not find those wires on the 88 F-150 2 wheel drive, because the 2 wheel wiring harness does not have the transfer case wires in it.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #9 (permalink)
Old 07-07-2011, 05:56 AM
Is there anyway of getting a wire from a 88 4X4 (at a junk yard) and adapting it into the 2wd harness ? Or was it set up just for 2wd only and cannot be hooked into it ?
  #10 (permalink)
Old 07-07-2011, 07:16 AM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
Maybe these diagrams will help you.
1990:
Click the image to open in full size.
1988:
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #11 (permalink)
Old 07-07-2011, 04:06 PM
OK, thanks! I'll print it off and look at it.
  #12 (permalink)
Old 07-07-2011, 05:22 PM
The first diagram is great for the 1990. The other ones are for a 88 truck with electronic shift. Mine has standard lockouts, not electric. Mine also has a 5 speed standard transmisson and 4.9L engine if that makes any difference.
The wire hookup to the transmission and transfer case is the only issue I'm trying to resolve at this point.
I want to see how the 1988 F150 2wd transmisssion wire hookup compares to the same year with the 4X4 transfer case added. I need to see how they are different and if I can use my 2wd wiring and adapt it to a 4X4 setup. I could use the 1990's wiring from the transm. and transfer case and splice into the 88's if I could figure how to do it. The 1990 seems to have a completely different wire set up then the 88. I didn't figure there would be that much difference for 2 years since the body and everything else is the same. If you could find the diagram for the 1988 2wd, and the 1988 with 4 wheel drive without the electronic shift module that would be great.
  #13 (permalink)
Old 07-07-2011, 06:33 PM
subford's Avatar
Not at all.
The last 88 diagram is the one for standard lockouts, not electric.
Look at the bottom right of the PG 78 diagram.
Above is all the diagrams that are in the EVTM for the F-series in 1988 for 4-wheel drive.
__________________
subford@gmail.com
  #14 (permalink)
Old 07-07-2011, 07:14 PM
lincolncobra4.6 lincolncobra4.6 is offline
lincolncobra4.6 is starting off with a positive reputation.
no underhood main box on this year, there are fuseible links in wire harness and the 2 relays for main & fuel pump power.
  #15 (permalink)
Old 07-07-2011, 07:18 PM
subford's Avatar
Quote:
What are you talking about?
__________________
subford@gmail.com
Tags
1988, 351, 50, 88, box, f250, find, ford, fuel, fuse, guage, harness, hood, radio, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
