Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Why is My Power Window Not Working?
Guide to diagnose trouble and recommended solutions
Drivers Electric Window not Working
I'm having the same problem with my newly acquired '96 F150. The passenger side worked great at first but it now doesn't work at all, just like the driver's side. It looks like power goes to them since the amp meter needle moves when I hit the switch to either window. Is there a relay that could be bad? Or is this the same symptom that you guys experienced and was fixed by the motor gear kit?
Bryant
Bryant
Unless a window guide is messed up or something, the cause is almost always a worn-out commutator or brushes in the motor. Time for a new one.
If the pegs on the back of the gear in the window motor's gearcase have crumbled as discussed above, the window motor runs with a rrrr-rrrr-rrrr rhythm to it, but it won't move the window. In that case, I will clean out and fix the motor gearcase, if it is NOT the driver window. I use the driver window a lot, the others rarely, so the driver's window gets a lot of use in comparison. If the pegs crumbled on the driver's motor, the wear-out of the motor's commutator or brushes is not far behind due to use. That's what I have found out in many years and many Ford Lincoln Mercury vehicles. I got tired of pulling a motor again, a year later to replace it. And I learned to NEVER buy a rebuilt motor... a lot of crap that soon died, or developed the broken-peg problem, and had to pull off door panel and do it all over again.
Oh, and to replace the window motors, search for a procedure that you drill the holes to get access to the motor screws, DON'T drill out the rivets!
Great info Torky! Yes it is a Volt Meter on my dash. I'm used to my '70 F-250 with an Amp Meter. I did try the switches with the dome light and it does dim so the motors are getting power. I also switched the switches when the passenger side was the only one working at the time and it didn't change the problem. It's weird that one day the passenger motor is strong and perfect, then next day....nothing. You really have to drill holes to get to the fasteners? Bummer!!!! Thanks guys
Bryant
Bryant
teerex
1997-2006 Expedition & Navigator
11-11-2013 08:30 PM
