Universal Joints
Universal Joints
Hi,
My truck has developed a whirring from the rear end when I accelerate. It also clunks if I let on the gas and then re-accelerate. Pretty sure the universal joints are starting to go.
Does anybody have some advice on replacing these things? Last time I did this, I had a shop press the new joints on for me. Can I do this myself somehow?
Greg
1989 Ford F-250 Super Cab 460 EFI 2WD
Greg
Universal Joints
A large C-clamp and sockets always worked for me. One socket that will go thru the yoke when pushing, and a larger one that the cup will go into on the way out the other side.
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Universal Joints
Check the pinion nut on the rear end also. I had this happen to my 88 F150 and I also noticed this on my 89 F250 the other day...just grab the pinion shaft and see if it moves around...that sounds more like the problem than the u-joints...if it is that, you gotta drop the driveshaft anyhow, so it probably wouldn't hurt to replace them anyhow..
Good luck!
Phil
Good luck!
Phil
Universal Joints
i use a vise and sockets of the appropriate size. but a c-clamp would defenately aid in keeping them together. make sure when you go to drive the bearings in, you pound(if you are using a hammer)on them straight, as even the slightest angle might mess the needle bearings up inside the cup.
