88 F-250 Rear Main Seal fix/replace - Ford Truck Enthusiasts Forums
Old 06-13-2011, 01:38 PM
UtahCowboy's Avatar
UtahCowboy UtahCowboy is offline
UtahCowboy is starting off with a positive reputation.
My rear main is driving me nuts. I carry cardboard in the bed right now to put under the truck whenever I park.
I am not really looking forward to dropping the tranny, but the leak is just too much anymore.
How many man hours an I looking at for replacement if I do it in my driveway?
Is there a productout there that I can add to the oil that really works?
Is there anything else I can do, instead of taking it apart?
Old 06-13-2011, 04:40 PM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
ive used lucas oil leak stop and it always seems to work for me. it usually just slows down the leak though. id give that a shot if its really bothering you and you dont want to drop the tranny just yet. i dropped my manual tranny about 2 months ago and it took me like 9 hours with 2 people helping me. i ran into just about every little problem that was possible. what kind of motor and tranny do you have? and there isnt anything else you can do to replace the rear main without taking everything apart.
Old 06-13-2011, 06:42 PM
MFogarty1996's Avatar
MFogarty1996 MFogarty1996 is offline
MFogarty1996 is starting off with a positive reputation.
Ive heard from a few of my mechanic friends that say if you use full synthetic all the oil particles are small and uniform, but in conventional they are all sizes. Meaning that the small ones get through the spaces, as with conventional the bigger ones block up the spaces and plug it up so the smaller ones cant get out. So i figure that if you are using synthetic try conventional and see what happens. I used to use conventional then switched and now i have the same issue so im going to switch back to conventional or a blend the next oil change and see how it works for me. I dont know if itll work for you, thought id try and help someone on here as much as you guys help me.
rear main leak Maverick1978 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-25-2012 12:16 AM
Rear Main Seal Problem 2002 7.3 jjpgilesva 1999 - 2003 7.3L Power Stroke Diesel 18 07-16-2012 11:36 AM
390 rear main seal leak mikev 1967 - 1972 F-100 & Larger F-Series Trucks 7 11-12-2010 02:01 PM
Rear Main Seal Problem 2002 7.3 jjpgilesva 1999 to 2016 Super Duty 9 06-24-2010 10:20 PM
1987 ford ranger rear main seal adroc104 1987 - 1996 F150 & Larger F-Series Trucks 1 04-03-2003 08:27 PM
Tags
150, 250, 88, change, diesel, f250, fix, ford, main, rear, remain, replace, replacement, replacing, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
