Ford 6.8L V10 Vacuum Line Diagram - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 06-13-2011, 12:01 PM
raidscsi's Avatar
raidscsi raidscsi is offline
raidscsi is starting off with a positive reputation.
I think I found the source of my engine troubles.
Here you can see it sticking right out in plain view in the open, I feel really stupid for not seeing this. The way the smaller hose wraps in a coil should have given it away too.
Here you can see where it leaves the intake manifold and where it is literally just sitting in the hose adapter.
After pulling the heater hose off, and the PCV valve, inspecting the smaller hose that connected them shows that its not one hose but two joined by a small threaded pipe, like you would find inside a table lamp!!!!
Here is the partially repaired view, I used a 5/8" Elbow at AutoZone marked "Ford PCV", the 1/4" to 5/8" and a 10" section of new fuel hose.
Here is the emissions control label on the hood.
The diagram clearly shows the line coming from the intake and then splitting into two, one going to "Main Vac", and the other to a "FPRC", which is related to the Fuel Pressure Regulator.
The PCV valve is labeled to be connected to "Main Vac", but not shown where on the diagram.
I have the vacuum line from front of intake to the PCV valve with not other connections. Which according to the diagram is wrong.
Should I have replaced the PCV valved? Do they go bad?
Also a big thanks to everyone here for their ideas and suggestions.
Old 06-14-2011, 07:33 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the V10 forum.
Old 06-17-2011, 04:33 PM
Trey Trey is offline
Trey is starting off with a positive reputation.
I have all the diagrams for the 2007 model, let me know if you need something.
Old 06-17-2011, 10:14 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
He has a 2000. The 2007 isn't going to be the same.
The PCV valve IS shown on the diagram (on the left).
Yet another tire thread, with pictures! raidscsi 1999 to 2016 Super Duty 21 10-25-2011 10:14 AM
Snow Plow Options raidscsi 1999 to 2016 Super Duty 29 10-21-2011 10:18 AM
6.8L V10 Gas Mileage Report raidscsi 1999 to 2016 Super Duty 6 08-29-2011 06:10 PM
Post pictures of Frankentrucks raidscsi General Automotive Discussion 7 08-18-2011 08:55 PM
Tailgate handle latch broken. raidscsi 1999 to 2016 Super Duty 3 08-15-2011 04:34 PM
Tags
2001, 2006, 68, controls, diagram, engine, f450, ford, hose, lines, litre, pcv, v10, vacum, vacuum, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
