What weight of oil does everyone use? - Ford Truck Enthusiasts Forums
Old 06-13-2011, 07:45 AM
redandwhite_72 redandwhite_72 is offline
redandwhite_72 is starting off with a positive reputation.
I went to Napa yesterday to get the spark plug removal tool. When I was there I picked up some 10W30 oil for my 2005 5.4L King Ranch. This will be the first time I've changed oil on the first Ford I have ever had. When I got back to remove the broken spark plugs, I saw on the lid it says 5W20.
Do you think 10W30 will be ok in it. Or should I take it back and get 5W20?
Side note--- I changed my plugs and only had 2 that broke. Got the removal tool and they came out great. (Praise the Lord) Thanks for everyones tips and what not on the plug removal.
Old 06-13-2011, 08:00 AM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
5w20 here, full synthetic. It's what Ford recommends (5w20 that is, the full syn is my choice), and it's the only thing I'll put in it.
Old 06-13-2011, 10:18 AM
tooldad tooldad is offline
tooldad is starting off with a positive reputation.
Like MCDavis, I stick with factory recommended 5w20. I typically use the MotorCraft SynBlend though, also factory recommended. No problem using full syn though, if you so choose.
Old 06-13-2011, 11:24 AM
snowdog79's Avatar
snowdog79 snowdog79 is offline
snowdog79 is gaining momentum as a positive member of FTE.
Motorcraft 5w20 semi-syn/Motorcraft filter.
Old 06-13-2011, 11:36 AM
YoGeorge YoGeorge is offline
YoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to behold
5W20 is the recommendation; in 94k miles, my 4.6 has lived on 5W20 for its entire life, consumes no oil, makes no noises, and runs wonderfully. I would stick with the factory recommendation--although the heavier oil may be OK in a pinch in warmer weather/warmer climates, the valvetrain on the modular motors needs oil STAT upon startup or it will wear prematurely and cause problems.
Good luck for a long life from your new-to-you Ford truck.
George
Old 06-13-2011, 11:50 AM
pb34's Avatar
pb34 pb34 is offline
pb34 is starting off with a positive reputation.
As mentioned, I use 5W20 full syn as well. I try to stay with what's recommended when possible. I would assume that the 10W30 would be fine in warmer climates as George said since some people have used even heavier oil to get rid of the cam phaser noise but if it were me I would switch back to recommended after.
Old 06-13-2011, 12:57 PM
hcbph hcbph is offline
hcbph is starting off with a positive reputation.
Oil
5W20 in both of mine. It's the mfg specified oil, my 4.6 has been going strong for the last 175K so can't complain on that.
I've read of some people trying 10W30 and higher weights especially when they have cam phaser issues. It may quiet it temporarily but I suspect in the long term they're doing more damage than good. I would suspect it will take longer for the oil to circulate on initial startup, potentially starving certain areas of the engine of oil.
If it were me, I'd take it back and get the right viscosity oil.
Old 06-13-2011, 08:21 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
+1 on MC 5W20. Walmart sells both the oil and MC F820S filters.
Supposedly, you can use the thicker oil with no issues, but it'll come at the expense of lower mpgs. I'd exchange it.
Old 06-13-2011, 10:28 PM
Fox Fader's Avatar
Fox Fader Fox Fader is offline
Fox Fader is starting off with a positive reputation.
It's a long story behind 5-20. This is the short version.
Being in the business for many years, I was told from someone that knows what going on, that the reason some companies went to 5-20 is show better mileage in the cars and trucks by percentage. Why? Gov't ratings. The Gov't wanted to see better mileage out of vehicles so going with lower viscositys, auto manufactures could achieve it.
That said, use 10-30 and don't sweat it. I do and have since 04, the first car I had that recommended it.
Old 06-14-2011, 12:07 AM
Ford has been recommending 5W30 from the days of my wife's old '86 Escort GT and 5W20 since 2001 or so. The lower weight when the engine is cold is a distinct advantage in getting oil up to the cylinder heads which have a lot of critical moving parts. And I personally consider fuel mileage to be of major importance, especially with today's gas prices.
I remember when racing oils were straight 40 weight, or 20W50. Take a look at this website:
Joe Gibbs Driven - Synthetic Racing Oils
NASCAR cars use a straight 0W oil for qualifying, a 5W20 for unrestricted engines, and a 0W20 for restrictor plate engines. For long races in warm weather in the South. Guess what--lighter oils not only provide better mileage, they give you MORE HORSEPOWER with no downside that I have ever seen in the real world for engines designed for lighter oils.
The old days are gone, folks. So many folks think they are smarter than the engineers who designed their cars.
George
Old 06-14-2011, 12:36 AM
My old 88 BMW took 20W50, my old 84 Toyota took 10W40, wife's 99 Honda took 5W30, F150 takes 5W20, F350 takes 15W40.
There was a short period of time where my garage shelf looked like the oil rack of auto parts store when I still had all of these cars. Fortunately, I'm down to 2 flavors now...
Old 06-14-2011, 08:17 AM
thousand_mile_stare thousand_mile_stare is offline
thousand_mile_stare is starting off with a positive reputation.
Motorcraft 5w-20 and FL820S
Old 06-14-2011, 09:26 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
George
Well put George! Tried to rep you but...well you know.
Old 06-14-2011, 09:54 AM
MCDavis's Avatar
Arghhh
Rep Gods won't allow me to get George again either.
Old 06-14-2011, 11:41 AM
RISUPERCREWMAN RISUPERCREWMAN is offline
RISUPERCREWMAN is gaining momentum as a positive member of FTE.
The VCT's & Phasers demand a 5w-20 weight oil period! Especially upon startup! Anything else is just asking for trouble! Oh yes, a 5w-20 weight oil dissapates heat much better than a 10w-30 oil, so the hot weather argument is moot!!!
Ranger 1990 vs New owner (DTC 14 & others) AderisKD Ranger & B-Series 14 10-08-2015 03:12 PM
Bought a 04 f150 5.4...spark plug problems!? rwdfan 2004 - 2008 F150 34 02-28-2013 05:33 PM
The spark plug nightmare is over brianjordanf250 1999 to 2016 Super Duty 23 11-24-2012 02:01 PM
Changed spark plugs 5.4 3V @ 52k miles - pics D-Rock 2007 - 2014 Expedition & Navigator 11 07-26-2011 12:28 PM
Changed spark plugs 5.4 3V @ 52k miles - pics D-Rock 2004 - 2008 F150 8 03-29-2011 08:55 PM
Tags
1996, 2008, 2009, 351, 67, f150, ford, grade, motor, oil, run, sport, truck, tuned, type, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
