477 blown in '77 f900
Old 06-13-2011, 04:30 AM
svehn's Avatar
svehn
svehn is offline
I've got a 77 F900 tandem axle grain truck with the setback steering axle and the 477 motor. Well, this spring a connecting rod let go and damaged the block so it is unfixable. I have a 460 carbed sitti g around that runs great and isn't beig used. I was wondering if this would be a fairly simple swap, or will it be a complete PITA. Making/Re-using brackets for the front of the engine is no problem. Eve motor mounts wuld be ok. What I'm worried about is the bellhousing. It has the 3 range 13sp tranny in it with the low gears for the higher revving gas motor.
Any info would be great,
Thanks.
Old 06-13-2011, 01:18 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Bell pattern will be different.
"Lima" engines used in mediums would be a source for a bell that would work with your trans. 370s and 429s have the same bell pattern as your 460. According to some posts here, Roadranger 6610 and 6613 were available behind the 370/429s in the early '80s. Also mentioned was an SAE #2 adaptor.
What is the make and model of your trans?
fullbore1
Large Truck
02-23-2016 08:21 PM
Rimrock F1
18
01-10-2015 05:08 PM
76f250460
Large Truck
10-14-2014 05:48 AM
Wallingnuma
02-14-2011 04:00 AM
mikehallbackhoe
401, 477, & 534 SD Engines
01-29-2010 06:28 AM
Quick Reply: 477 blown in '77 f900
