Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-13-2011, 04:30 AM
svehn svehn is offline
Garage is empty, add now
svehn is starting off with a positive reputation.
477 blown in '77 f900
I've got a 77 F900 tandem axle grain truck with the setback steering axle and the 477 motor. Well, this spring a connecting rod let go and damaged the block so it is unfixable. I have a 460 carbed sitti g around that runs great and isn't beig used. I was wondering if this would be a fairly simple swap, or will it be a complete PITA. Making/Re-using brackets for the front of the engine is no problem. Eve motor mounts wuld be ok. What I'm worried about is the bellhousing. It has the 3 range 13sp tranny in it with the low gears for the higher revving gas motor.
Any info would be great,
Thanks.
  #2 (permalink)
Old 06-13-2011, 01:18 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Bell pattern will be different.
"Lima" engines used in mediums would be a source for a bell that would work with your trans. 370s and 429s have the same bell pattern as your 460. According to some posts here, Roadranger 6610 and 6613 were available behind the 370/429s in the early '80s. Also mentioned was an SAE #2 adaptor.
What is the make and model of your trans?
Tags
1979, 477, 77, axle, build, diesel, f900, ford, grain, gvwr, northern, ohio, sale, tandem, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
