How to clear codes?
Old 06-12-2011, 08:49 PM
Jules3084's Avatar
Jules3084
Jules3084 is offline
How to clear codes?
Could some please help direct me as to how to clear codes without a scanner? I've been searching for awhile now, and I've been unable to find the info.
The 1995 F150 has three codes, but I don't know how old they are.
I've never had to try clear them to verify they are current.
Thanks
Old 06-12-2011, 08:52 PM
McCormick's Avatar
McCormick
McCormick is offline
Pull a battery cable and leave it unhooked for a while
Old 06-12-2011, 09:06 PM
Jules3084's Avatar
Jules3084
I pulled the battery cable for 30 minutes, and that still didn't clear them.
Seems like a long time doesn't it?
Old 06-12-2011, 09:38 PM
danr1's Avatar
danr1
danr1 is offline
Which codes If they are KOEO or KOER codes and you haven't corrected the issues the codes will reappear once power is restored and the self test is ran again. CM codes will be gone, reappearing again if condition not corrected after a short test drive.
You don't want to disconnect the battery to clear codes and that isn't the proper way to do it. Doing so looses its adaptive strategies its worked out over a period of time. It will have to start over from scratch once that is lost, doesn't help when trying to diagnose a problem either.
Someone correct me if I'm wrong, haven't used the jumper method in a long time, use a Innova 3145. To clear the codes allow the self test to begin then remove the jumper wire.
Ford Fuel Injection » How To Run a Self-Test
Old 06-13-2011, 11:32 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,156 Likes on 914 Posts
X2 on that statement in bold.
LEDman
2017+ Super Duty
07-06-2021 06:55 AM
sunuvabug
10-31-2019 09:17 PM
bebo9b
6.4L Power Stroke Diesel
01-02-2017 07:59 AM
GreaseGun Joe
10-18-2015 11:38 AM
nealneu
1999 to 2016 Super Duty
03-30-2011 11:15 AM
Quick Reply: How to clear codes?
