The alarm keeps going off for no reason - Ford Truck Enthusiasts Forums
Old 06-12-2011, 08:00 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
My new to me 1998 F150XLT has a strange problem. The alarm seems to go off whenever it feels like it. Sitting in front of the house (3 times), on the ferry boat with me in the cab with the key in the ignition (once), at the store (once) and once at my nieces house. This all in the last 2 weeks. Shuts right off when you hit the reset button, well except on the boat, the remote would not work at all (no door locks, nothing), but then the guy next to me had the same issue with his remote for his Honda. Had to used the key in the door to shut it down. I suspect that was an radio interference issue with the ferry's diesel/electric drive system as soon as I got off the boat he remote worked again. Is there a sensitivity adjustment on it or what. The 1995 Exploder sits right next to the F150 at the house and it never does this.
Old 06-13-2011, 04:29 PM
Bear 45/70's Avatar
Nobody ever have an issue with the alarm system?
Old 06-14-2011, 02:04 PM
txbest1980 txbest1980 is offline
txbest1980 is starting off with a positive reputation.
i have never had a problem with my F150, but i did have an issue with my Cadillac STS before...i traced it down to my money clip being magnetic and me throwing my keys directly on top of the magnetic part. the remote would then set my alarm off prematurely and i would have to disconnect the battery for roughly 20 to 30 minutes to reset the entire system from it going off randomly. im not saying this is your issue, but it may be possible
Old 06-14-2011, 02:29 PM
Bear 45/70's Avatar
Money is clip non-magnetic, lucky bullet is non magnetic, none of the keys are magnetized, so that's not it.
Old 06-14-2011, 03:04 PM
just a shoot in the dark...
Old 06-14-2011, 03:14 PM
Bear 45/70's Avatar
I appreciate the response. So far no one else seems to have had issues with theirs.
Old 06-14-2011, 06:41 PM
Scalemandave's Avatar
Scalemandave Scalemandave is offline
Scalemandave is starting off with a positive reputation.
Maybe a door jamb switch. Fords had problems with them. My daughter had a windstar that would set the alarm off & sometimes the interior lights wouldn't go out. Sprayed the crap outta the D/J switches & it went away.
Old 06-14-2011, 07:44 PM
Bear 45/70's Avatar
Quote:
Except the lights and door ajar system work flawlessly. I will however check it out.
Old 06-14-2011, 10:21 PM
Aftrmidnite Aftrmidnite is offline
Aftrmidnite is gaining momentum as a positive member of FTE.
Do you have a Military Base near you that flies aircraft in and out ? My old Garage opener had to be reprogramed once a month, if I left my Aerostar outside the alarm would go off, even if it wasn't set. I loose communication with my wireless weather station, which POs me as a reset looses all the history. I was at the mall one day and everyone with a GM vechicle was stranded for a little over half an hour. Try unplugging your underhood light, to see if the problem goes away. When my truck was new it would blink on and off, was fixed under warranty. Check to see if the fuse was installed at your brake resevoir. It was part of a recall, for the cruise control, catching fire.
Old 06-14-2011, 11:32 PM
Bear 45/70's Avatar
Quote:
No military within 50 miles and no flight paths anywhere near here. I will try the hood light. Yes, the cruise control recall was done.
Old 06-14-2011, 11:35 PM
jerem0621 jerem0621 is offline
jerem0621 is gaining momentum as a positive member of FTE.jerem0621 is gaining momentum as a positive member of FTE.
Next time it goes off put the key in the door and unlock the door.
I know, crazy as it sounds, it should work.
My truck did the same thing. Used the key in the door trick and it worked like a charm.
Hope this helps.
Jerem
Old 06-15-2011, 03:41 AM
Woke up at 0250 from a Harrier jump jet hovering overhead. Don't know what's going on, also half the county fire department is down the street on a call, via a neighbor.
Old 06-15-2011, 10:26 AM
Bear 45/70's Avatar
Hope this helps.
Jerem
The door lock thing works fine and is one of the ways listed in the owners manual to shut the alarm off. When the alarm went off on the ferry and the remote was inoperative, that was the only way to shut if off, other than disconnect the battery of course.
Old 06-20-2011, 01:45 AM
Bear 45/70's Avatar
Home alone, in bed and the damn alarm goes off at 1:30AM. Truck has been parked for 5 hours. The best part is it shut off by itself before I found my keys. Now that's just weird.
Old 06-24-2011, 02:22 AM
Bear 45/70's Avatar
Cleaned the door switches and it still does it for the next several days. Now it has stopped doing it. Not once in the last 5 days. Too weird for words. Maybe the truck is haunted (even thought to only PO is alive and well). If so I can live with a ghost/spirit. Hell, I live with a real live witch and have for 30+ years. That is witch as in Wicca.
Calling all Viper Alarm/Keyless/Remote start experts Firefighter 1406 1999 to 2016 Super Duty 2 12-10-2016 01:01 AM
Door keypad use sounds alarm??? pmyers 1999 to 2016 Super Duty 5 02-24-2016 07:38 PM
Need assistance programming new key fobs w/aftermarket alarm F350SDKammyo 1999 to 2016 Super Duty 0 10-24-2013 02:19 PM
alarm system red dirt 4x4 1997 - 2003 F150 0 09-07-2011 12:27 AM
1973 F-350 Intermittent missing (dead cylinder?) loses then regains power smithe26 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-13-2010 06:38 PM
Tags
2003, 2004, 2005, alarm, disconnected, edge, escape, f150, ford, international, problems, reason, time, trailer, truck, windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
