The alarm keeps going off for no reason - Page 2 - Ford Truck Enthusiasts Forums
Old 07-21-2011, 11:30 PM
FordMama57 FordMama57 is offline
FordMama57 is starting off with a positive reputation.
Did this issue get resolved and if so, what did you do? I was at dinner tonight and my neighbor called me to tell me that my alarm was going off. Then she said it stopped. And then started again. I came home and turned it off. 2 mintues later it started again. So I shut it off......then it came on AGAIN. Its been quiet for about 15 minutes now because I have not put the alarm on.. (its getting late) Just wondering if there is anything I can do.
Old 07-21-2011, 11:49 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
I did nothing to fix it. Has not done it in awhile until Wednesday afternoon in the Safeway parking lot in Seattle. I'm sitting in the truck and the alarm goes off, shut it off with the FOB and it hasn't happened again. I suspect it was someone with the same coded FOB setting their alarm. I just love computers. A buddy at the local Ford dealer said to disconnect the battery overnight and see if that helps or to unplug the alarm box overnight.
Old 07-21-2011, 11:54 PM
azking_Ranch's Avatar
azking_Ranch azking_Ranch is offline
azking_Ranch has a very good reputation on FTE.azking_Ranch has a very good reputation on FTE.azking_Ranch has a very good reputation on FTE.
Had the same problem with one installed on a 2005 F250, The alarm module was set to sensitive, every time a truck airplane went by off went the alarm. had the dealer adjusted twice before it worked without a 3am wake-up.
azkingranch
2011 F350 KR LB SRW Golden Bronze
Old 10-14-2011, 12:30 PM
Bear 45/70's Avatar
It's back. Now that fall has decended, the alarm going off has returned. Done it 3 times now and just now I am the only one home and the key were laying on my deck in plain sight so the button was not pushed by accident. So I am back to square one, with a haunted truck. Is there a way to shut it off.
Old 12-24-2011, 04:24 PM
Bear 45/70's Avatar
Still going off whenever it feels like it. Anyone know how to disarm the alarm? Please!
Old 01-29-2012, 12:58 AM
Bear 45/70's Avatar
This frickin' alarm goes off whenever it feels like it. I can be sitting it the truck, key in the ignition, ignition off and the damn thing goes off. Locked, unlocked, alarm set or not set, it just randomly goes off. Is there anyone than knows anything about this at all.
Old 02-04-2012, 11:07 PM
ambitious3 ambitious3 is offline
ambitious3 is starting off with a positive reputation.
Having the same issue
Any help on this issue would be appreciated I have a 97 F250LD that has a random alarm issue to. Truck has a factory alarm system and I do not even have to arm it, doors 100% unlocked, can even check that the thief light does not light up on the dash with exiting the truck and it will randomly go of. At this point I would even take advise on where to find the gem and what wires to cut to fully disable the activation and triggering system.
Old 02-06-2012, 02:42 PM
garbhead garbhead is offline
garbhead is starting off with a positive reputation.
my 1995 F-150 just now did it...I was sitting in the truck with the door open, looking for something in the supercab part...alarm went off. The remote entry fob was in the house, not even in my pocket. I went inside to get it, pushed the "panic" button and still going off(actually got louder) . I punched the "lock" button on the fob and it quit. Maybe having the door open triggers it somehow? That's why I googled this and ended up on here...
Old 02-09-2012, 07:16 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Try testing the truck battery cells. My 05 Mustang with factory alarm would go off at different times whenever. I tested the battery cells after a recharge one day as the car wouldn't start on a minus 30 day. Two cells didn't meet the specific gravity test so I replaced it. Haven't had a problem with the alarm since. Go figure.
Old 02-09-2012, 01:43 PM
Bear 45/70's Avatar
Quote:
Done this with the old battery and the new one.
Old 02-09-2012, 07:37 PM
Do you have a second key fob? Take battery out of the one you usually use and use your second fob. The 1st fob may have buttons partially stuck. If problem is still there at least you know the fob isn't causing the problem.
Hood switch's may also cause problems. just a couple of suggestions
Old 02-10-2012, 12:22 AM
Bear 45/70's Avatar
Doing the key FOB thing for the last week. So far only one alarm and that was in town outside a restaurant. Never at the house. The FOB in question came with the truck. The other 2 I bought.
  #28
Old 12-26-2012, 02:05 PM
mrpd114 mrpd114 is offline
mrpd114 is starting off with a positive reputation.
The alarm on my 2011 F-250 Super Duty just activated in my driveway. The truck has not been entered since last night. It was locked with no one around, keys were in my jacket pocket that I was not wearing. I retrieved my keys and the alarm stopped before I could use the fob. It sounded for about 30-45 seconds.
Calling all Viper Alarm/Keyless/Remote start experts Firefighter 1406 1999 to 2016 Super Duty 2 12-10-2016 01:01 AM
Door keypad use sounds alarm??? pmyers 1999 to 2016 Super Duty 5 02-24-2016 07:38 PM
Need assistance programming new key fobs w/aftermarket alarm F350SDKammyo 1999 to 2016 Super Duty 0 10-24-2013 02:19 PM
alarm system red dirt 4x4 1997 - 2003 F150 0 09-07-2011 12:27 AM
1973 F-350 Intermittent missing (dead cylinder?) loses then regains power smithe26 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-13-2010 06:38 PM
Tags
2003, 2004, 2005, alarm, disconnected, edge, escape, f150, ford, international, problems, reason, time, trailer, truck, windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
