290k+ NO PLAY, BUT EDGEGES ARE ROUGH
Old 06-12-2011, 06:59 PM
561DAN's Avatar
561DAN
561DAN is offline
Pulled the intake and air filter off of my '96 7.3. there is no play in the turbo at all. BUT, i am concermed because the leading edges are worn. It has the recalled airbox still on it. i am replacing it with the 6637. should i be concerned?
Old 06-12-2011, 08:00 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
If its not chipped and just evenly worn around, it's not as big of a deal. If its chipped, it will be out of balance and you will have more problems. I wouldn't be too worried if its just worn, but you can get a new wheel down the road sometime for about a hundred bucks.
Old 06-13-2011, 04:46 PM
561DAN's Avatar
561DAN
561DAN is offline
Its just the leading edges. I just got the truck and realized the original owner never did the recall on the airbox. I'm guessing it sfrom excessive sand getting by it. Is it possible to upgrade the wheel on that side to create more boost? like a hybrid?
Old 06-13-2011, 05:47 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Welcome to FTE!!!!!
The D66 that beans sells is just that... An upgraded compressor wheel and machined housing to fit it.
Old 06-13-2011, 06:09 PM
427 fordman
There is no upgraded wheel for our turbo unless you change turbos like Travis said.
SpringerPop
S. California Chapter
99
01-14-2014 10:32 AM
brentleedragon
Washington Chapter
03-24-2008 11:47 PM
Dave Sponaugle
22
12-08-2007 02:24 PM
peterdroy66
09-07-2002 09:06 AM
Quick Reply: 290k+ NO PLAY, BUT EDGEGES ARE ROUGH
