Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 06-12-2011, 04:49 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
Garage is empty, add now
SuperDutyScaler has a good reputation on FTE.SuperDutyScaler has a good reputation on FTE.SuperDutyScaler has a good reputation on FTE.
factory tech valve body questions
ok let me start by saying i have a 5.4 powered f-350 so.... anyways i bought a factory tech valve body on 12-29-09 and ever since installing it i have a very hard 1-2 shift. it will actually chirp 1-2 at any throttle input even at normal grandmom driving. Im having a very hard time getting hold of gregg so i need advice from someone about this. So question is i've done google searches and ever thing is about the FTVB in lightings?? i havent found one page of it installed into a super duty truck anywhere? is this normal for yous who have the ftvb to have it shift so f$cking hard into second gear? please i really need some help if not im going to install my factory valve body tuesday after work.
__________________
2004 F-350, XLT, SC, SB, FX4, 5.4, 4R100 w/ TransGo HD shift kit, 4.30 gears w/ stock LS, SCT X3, zoo dad mod w/ STOCK intake, Gibson stainless headers, SPD y-pipe, 51509 cat, Borla exhaust, 1" rear AAL, dually upper and lower overload spring, 08 diff cover, ProComp 22210 springs, more.....
  #2 (permalink)
Old 06-14-2011, 05:17 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Who did your custom tuning and did they do it before the FTVB was installed?
The line presser settings for the trans should be at stock setting with the valve-body in there.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
  #3 (permalink)
Old 06-15-2011, 02:53 PM
bryyce62's Avatar
bryyce62 bryyce62 is offline
<---- Say Hello to Jack
2013 Ford F-250
bryyce62 is a splendid one to beholdbryyce62 is a splendid one to beholdbryyce62 is a splendid one to beholdbryyce62 is a splendid one to beholdbryyce62 is a splendid one to beholdbryyce62 is a splendid one to behold
I have a FTVB. Had it since 2007. Love it. 03 5.4 4X4 3.73
Mine shifts very hard between 1st and 2nd. It took a little getting used to at first. I'd imagine that part of your problem lies in your 4:30 gears, probably makes what I feel quite a bit harsher. Like I said, it took me some getting used to the shifts, but now, unless I'm towing or racing to the next stoplight, I just take it real easy off the line. But I'd never consider going back to stock settings. It's one of the best mods I've made to my rig.
__________________
G-dub
Wag More, Bark Less.
  #4 (permalink)
Old 06-15-2011, 03:41 PM
phil6608's Avatar
I think you meant to say,(stock VB) not stock commuter line presser settings.
__________________
  #5 (permalink)
Old 06-15-2011, 03:59 PM
i had mike at five star do my custom tunes after i installed the FTVB. The first one i had would chirp 1-2 and 2-3 shift so i called back and they sent me out another new valve body, i installed it and 1-2 was still very hard but 2-3 was much better? i've had it for almost a year and a half so far and i cant take it. your truck should not chirp 1-2 going 15mph through my development. my neighbors look at me like im some young *****ing punk! Also factory tech website is no longer available, no one replies to my emails or phonecalls and i was told by two people that they shut down so who knows. All i know is a unch of people with super duty trucks said they had them and would never recomend it or buy another one, so you can add me to that list as well.
__________________
  #6 (permalink)
Old 06-15-2011, 04:01 PM
and why would my 4.30 have anything to do with it chirping 1-2 shift? i have a little 5.4 not a 600HP diesel. the trans should shift the same weither i have 3.73, 4.30, or 4.88's.
__________________
  #7 (permalink)
Old 06-15-2011, 05:54 PM
bryyce62's Avatar
2013 Ford F-250
Quote:
Yes, you're right.
Quote:
Does your transmission hold 1st longer than it used to before the VB mod?
Well, I don't know the physics, technically, but because your engine winds up a little faster with the 4:30's the shift would be firmer.
I had a chat with a member on here a while back, (reax) (and to the best of my recollection) about this very topic, and he indicated that when he re-geared from 3:73 to 4:30 the shift of his tranny, with a FTVB, went from hard to violent. The gear change affected the firmness of the shift.
__________________
G-dub
  #8 (permalink)
Old 06-15-2011, 06:32 PM
phil6608's Avatar
There's a guy Ive talked to,(Stoffer) about changing springs in the vale body to help with the hard shift.
I sent him a PM and asked him to pop in here to see if he can explain it to you.
Otherwize you could try a different VB.
I run a BTS valve-body in my truck with 4.11 gears and 600RWHP. And unless I'm trying to chirp the tire ,it shifts fast but beautiful from first to second gear.
BTS.- Brians Truck Shop
__________________
  #9 (permalink)
Old 06-15-2011, 07:50 PM
STOFFERJ STOFFERJ is offline
STOFFERJ is starting off with a positive reputation.
Phil, I have not messed with the springs in the 4r100 only the 4r70.
The only advice I can give the OP is to go back to the stock valve body and do the line accumulator mod...
  #10 (permalink)
Old 06-15-2011, 07:54 PM
I ran a Factory Tech valve body in my Harley Truck for about 50 miles .... BTS or Punisher will be building my next one
Tags
2004, 46l, 4r100, 54, body, f150, factory, ford, gear, lightning, questions, superduty, tech, upgrade, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
