Stuck differential
Welcome! Are you sure the problem is in the differential? Did it make any loud noises, smell bad, or get hot before it locked up? And just how abrupt was the sudden stop? Could it be that a bad wheel cylinder on the right rear has locked up that side? Jack up the right rear and see how easily the hub comes off. Also see if you can turn the axle.
SNIPER168308
03-05-2011 04:51 PM
