Another Duraspark II Question: - Ford Truck Enthusiasts Forums
Old 06-11-2011, 10:36 PM
windsor8689's Avatar
windsor8689 windsor8689 is offline
windsor8689 is starting off with a positive reputation.
I went up and down the threads of the duraspark conversions, I understand the wiring, and how i cant put a 302w distributor in a 351w.
I read alot of fellow members got donor motors with the setup already in place. And I also found out that alot of the parts can either be found in a scrapyard or a local parts store.
I got a 69' 351w, Im in the process of rewiring the whole truck from Rebel wiring, so id like to have a newer ignition setup.
My question is: Couldn't I just go to a local auto parts store and ask for a Distributor &(cap n rotor), Ignition module, coil from a 1976 Ford LTD with a 351w? Would the distributor bolt right in my 69' block? And run my wires to the ignition module to coil etc etc.
Am i missing something???
Thanks for your time guys
Old 06-11-2011, 10:41 PM
sparky's Avatar
sparky sparky is offline
sparky is starting off with a positive reputation.
Yup you nailed it..... it is actually a fairly easy swap if you know how to put in a distributor and read a basic wiring diagram so go for it...........
Duraspark II Conversion Basics
Old 06-11-2011, 11:45 PM
Thanks for the link sparky, then that's what ill do! Another question: do I still use the voltage regulator specificly for the 76 ignition setup or does the regulator work for lots of years?
Old 06-12-2011, 10:13 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The voltage regulator is a function of the charging system, not the ignition. That won't matter for your Duraspark swap.
While your plan to get the parts you need is a great one, and will fit perfect, keep in mind that the timing curve built into the '70's distributor is not the most ideal for performance, since they were set up for smog motors. If you take your new distributor to someone who can recurve it, your engine will run a lot better.
Old 06-12-2011, 04:30 PM
Good looking out 52 Merc , I Never thought of the smog control.....thats something i need to consider changing in the near future. Im just getting much closer to firing this baby up .
Duraspark II Conversion - How To dyingtolive Ford Inline Six, 200, 250, 4.9L / 300 294 12-03-2016 04:28 PM
Duraspark questions.... QwkFox Electrical Systems/Wiring 2 12-25-2013 09:27 PM
Duraspark II Wiring Harness Questions AbandonedBronco 1978 - 1996 Big Bronco 0 08-06-2010 10:57 AM
Ignition module burns out rcook18 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-06-2004 01:35 PM
Where is the ballast resistor in the Duraspark II ignition? ClatonK Electrical Systems/Wiring 4 01-04-2004 03:51 AM
Tags
curve, duraspark, smog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
