1997 f150 with 5.4l loss of power and mileage - Ford Truck Enthusiasts Forums
Old 06-11-2011, 10:44 PM
93turbo 93turbo is offline
93turbo is starting off with a positive reputation.
hey my 1997 f150 2wd with a 5.4l triton motor has 267,xxx miles on it. the only things that ever needed replaced were the alternator and coil packs. i put an insys usa intake on it and true dual 2.5" glasspacks. it ran great for about a month and i got between 18 and 20 mpg. and now it seems less snappy and i get 14mpg no matter what. this truck is crazy reliable and the frame and body are spotless. i need help on getting my economy and power back so i dont have to sell it. thanks
Old 06-12-2011, 12:35 AM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
Ever done the plugs on it? May want to do plugs if you haven't, and the seafoam treatment is very high up on my "recomend" list.
Old 06-12-2011, 07:27 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
Have you tried to scan for codes?? sometimes there might be codes without the CEL
Have you cleaned the MAF sensor?
Have you checked for vacuum leaks?
Have you cleaned the throttle body?
Old 06-12-2011, 11:01 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
I would take that intake off, clean the MAF, and see if that doesn't take care of it. Not sure what kind of filter your new intake uses, but oil based filters are known to cause problems with MAF contamination.
Old 06-24-2011, 10:41 PM
Plugs haven't been changed in a while only because they are a bear to change. MAF sensor is fine and the intake is spottless. My filter does not use oil. I was thinking more along the lines of plugged up cats but Idk.
Old 06-24-2011, 10:44 PM
I also gave it a bottle of injector cleaner which helped a little
Old 06-25-2011, 12:09 AM
Plugs helped mine a TON. Yes, they were a pain in the *** but it needed to be done.
Old 06-25-2011, 12:24 PM
yeah ill see about talking the old man into letting me do it again
Old 06-26-2011, 12:08 AM
Well, let me add some info here, mine had 259,*** miles on the originals.
What mpg should a 1997 Ford F-250 XLT 4X4 with a 7.5 (460) fordinmudd 1987 - 1996 F150 & Larger F-Series Trucks 11 06-05-2016 11:46 PM
Need help Tj Megan Rider Modular V8 (4.6L, 5.4L) 3 12-01-2015 09:15 AM
Avg mpg for 2004 F150 5.4l? shockr4 2004 - 2008 F150 22 02-13-2014 11:26 PM
air filter abieleski 1997 - 2003 F150 6 06-24-2013 07:54 PM
1997 f-350 diesel / fuel economy mezcalero280cal 1994.5 - 1997 7.3L Power Stroke Diesel 19 02-13-2012 08:23 PM
Tags
2002, 54, 54l, f150, ford, insys, intake, loses, losing, loss, maf, mpg, power, sluggish, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
