1993 302 lower intake manifold
1993 F150 302 EFI lower intake manifold leaks badly at the thermostat housing. Years of corrosion have eaten away the aluminum on the manifold by the bypass hose area. I need a another lower manifold to repair. My question is what year 302 EFI manifolds will fit the application? 1987-1996?? Thanks.......
on
Just to be safe I'd suggest you limit your search to the years '87-'94 since they moved the IAT sensor from the lower to the airbox when MAF was introduced around 1995. This isn't a hugh deal if you were to get a lower without the port for this sensor.. you could just drill and tap a hole, but why bother if it can be avoided. You should have no problem finding another lower either, the 5.0 was a very common motor.
jeff9942
26
03-04-2022 01:50 PM
quickieR
09-19-2015 10:03 PM
dvldog458
05-07-2005 12:55 PM
parshdude
04-15-2005 07:48 PM
