2001 ford ranger timing issues 3.0 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-11-2011, 01:34 PM
jerrygallion jerrygallion is offline
jerrygallion is starting off with a positive reputation.
need help about had it my 2001 ford ranger 3.0 at 160,000 miles blew a head gasket so i figure i would just rebuild the whole motor and have the heads shaved and redone well i did all that new cam and crank sencers new injectors everything i can think of can still can't get it to run when i tore the motor down i didn't mark the camshaft synchronizer so i bought that tool i needed still not running right can get it to fire up and run but backfires any sugestions thanks
Old 06-13-2011, 07:30 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
It has to be asked, so don't get offended: Did you hook up the plug wires correctly?
Old 06-13-2011, 12:04 PM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
Did you have the #1 piston on top dead center on the compression stroke when you installed the Cam sync. ? It sounds like its 180 degrees out of time.
2001 ford ranger rob2069 Ranger & B-Series 6 09-19-2014 12:44 PM
Installing cam position sensor shaft in 2001 3.0 Ythomas Ranger & B-Series 2 06-16-2013 03:34 PM
2001 ford ranger 3.0 synco problems jerrygallion 3.0L V6 1 08-26-2011 11:41 PM
removing the drivers side cylinder head 2001-ranger Ranger & B-Series 1 10-06-2010 12:10 AM
Exhaust fumes in the radiator. 2001-ranger Ranger & B-Series 6 10-05-2010 11:21 PM
Tags
1977, 2000, 2001, 2007, 30, controls, engine, f150, ford, gasket, head, ranger, replacement, set, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
