E-150 No Spark @ Coil - Ford Truck Enthusiasts Forums
Old 06-11-2011, 12:32 PM
DCClark DCClark is offline
DCClark is starting off with a positive reputation.
Hello,
I have a problem with a 1994 Econoline 150 with 302, aod. The van suddenly died while driving it. Thinking it was the ICM, that was the first to be replaced. Then went ahead and replaced the Coil as there was no spark there. Then found this diagnosis online:
Part 1 -Ford Ignition Coil Test (4.9L, 5.0L, 5.8L)
Test 1 and 2 tested out ok, I got to test 3, which is testing the ignition coil switching signal and got no pulse from the LED, so then it says go to step 4 to test the pip. After going through that and trying to test the PIP (step 4) when probing the #1 ICM wire (pip signal wire) with the black side on the wire and the red connected to the battery (positive) the LED stays halfway lit. Then when trying to crank the motor the LED appears to blink, but then the motor starts and stays running until I remove the connection to the battery. If I do not have this 'jumper?' connected there is no spark and it just turns over. I am thoroughly confused at this point. Anyone have any suggestions? Thanks in advance.
Old 06-15-2011, 11:15 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
Did you ever figure it out? I had that problem with my truck and found that it was the PIP sensor inside of the distributor. Maybe that test was worded backwards and the red wire on the led goes to the ICM wire and the black to ground.I carry a spare distributor in the truck now just in case it happens again.
Old 06-18-2011, 12:10 AM
Actually I ordered the PIP just to rule it all out since everything else in the ignition line is new. I will post back once it comes in and I get to try it out. It has me baffled, especially the part where it will run if I put that 'jumper' in line!
Old 06-25-2011, 04:33 PM
Replaced the PIP and it worked. Was fun, but it cured the problem. Van back and functional, still have no idea how it ran when 'jumpering'.
Old 06-25-2011, 08:52 PM
393STROKER's Avatar
Thumbs up PIP
After I built the stroker motor and took it out on it`s maiden voyage it died at the first stop sign.I tried everything to figure it out,and thats when I looked up this sight.Some guys suggested the PIP might be bad,but since I had a brand new MSD billet distributor I had mt doubts but I swapped in the old one and it worked. I called MSD and they said that the PIP sensor that they use is factory Ford.The warranty had expired but they swapped it out for me anyway.That one had me stumped for awhile.
1996 CLUBWAGON NO SPARK red5standingby 1987 - 1996 F150 & Larger F-Series Trucks 4 12-23-2016 03:55 PM
Great web site for ignition and other test how-tos brokeasajoke 1987 - 1996 F150 & Larger F-Series Trucks 3 08-24-2016 04:20 PM
No spark engine cranks gimage 1987 - 1996 F150 & Larger F-Series Trucks 0 05-31-2016 11:47 AM
No spark issue-- actually, single spark..? exidor12 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-13-2015 07:34 AM
Replace PIP or Replace Distributor? DesertZuki 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-04-2015 12:16 PM
Tags
150, 1963, 1994, 1999, 460, 79, coil, died, e150, econoline, ford, icm, ignition, located, spark, suddenly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
