1984 ranger dash
1984 ranger dash
i have a 84 ranger which im putting up on 40's or bigger but have a question about interior. i am wanting to make a new dash (out of diamond plate) and was wondering if i would use like an old ford speedometer or the whole dash? do i need anything extra to make it work with my new set up?
thanks
justin
thanks
justin
Mostly this depends on the transmission you are using. Does the transmission supply an electronic or a mechanical signal. Mechanical signal involves a cable and gear at the transmission with a cable going into the speedo. Electronic is harder, but still possible to do. Mechanical is easier to do because you can compensate for axle ratio and tire size by swapping a plastic gear between the cable and the transmission. Does this help?
