Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 06-11-2011, 11:11 AM
Sam Menard Sam Menard is offline
2011 Ford F-250
Sam Menard is starting off with a positive reputation.
Oil changes
I noticed that there is a display guage which indicates % engine oil life. I'm not sure if it takes into account vehicle and driving habits, but at what percent would you think about changing the oil?
Sam
  #2 (permalink)
Old 06-12-2011, 03:15 PM
19-kilo's Avatar
19-kilo 19-kilo is offline
2001 Ford Excursion
19-kilo is starting off with a positive reputation.
curious about this as well... I did not see in the manual any specifics on what determines the oil life monitor
__________________
2001 4x4 Forged 7.3L "Zombie Slayer" aka the "Big Bus": DP tuner - 60T 80E 120R, MBRP 4", RRD 6637, Isspro EV2 - EGT Trans temp Boost with AIH delete, Bilsteins, HyperFlex Swaybar and endlink bushings, Rancho SS, FRx, HPX
2011 Raptor SuperCab 6.2L
  #3 (permalink)
Old 06-12-2011, 07:18 PM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
I don't use that monitor but do reset it after each oil change. Just change it based on miles. My first was at 1800, then will be around 5000 for now on. Use full synthetic oil, so I think 5000 is a good number. The manual does say 7500 with no towing and 5000 if you do tow.
On my old Chevy we would be able to get about 7000 miles before the oil life monitor said 0%, but never let it go that far.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #4 (permalink)
Old 06-13-2011, 09:00 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
I waited the 5 months on mine (I'm only at 3700mi or so) and it still said 30% left. I knew it needed it done so I took it in anyways. Not sure how "smart" it is but I'll go by mileage/months over that thing (unless using it in extreme conditions, which I won't be).
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #5 (permalink)
Old 06-14-2011, 07:25 AM
Buckholz Buckholz is offline
Garage is empty, add now
Buckholz is starting off with a positive reputation.
Just did my 4th oil change, at 20k miles. Loving the 6.2L, use for towing and running around empty. Use Penzoil Ultra oil and motocraft filters.
I preset my oil minder to start at 60%, easy read the manual.. And pretty much the warning light comes on at about 5000 miles. Working great for me!
  #6 (permalink)
Old 06-14-2011, 02:50 PM
loganworks loganworks is offline
loganworks is starting off with a positive reputation.
I now have about 4500 miles on my truck and checked the oil minder today and it still reads 100%. Hows that according to it I have at least another 4500 to go. I think it is a joke!! I always change the oil between 4 & 5000. I have been towing a lot.
__________________
2011 F250 XL 4X4 FX 3.73 6.2
  #7 (permalink)
Old 06-14-2011, 04:23 PM
Byram's Avatar
Byram Byram is offline
Byram is gaining momentum as a positive member of FTE.Byram is gaining momentum as a positive member of FTE.
I put 4K on mine & it still read something like 86% - I changed it & now change every 3-4K I may be wasting oil/cash but mines on the dirt roads a lot, I tow/idle frequently and lately 100° heat outside -
IT Just makes me feel better.......
I don't trust the thing.
__________________
2013 F-350SC Lariat
6.7; 3.55 EL; 4x4; B&W Turnover; Ranch Hand; Coming Soon: BFG M/T 285's; Oasis XD 4000 OBA & Aux Battery
"Peace is that brief glorious moment in history when everybody stands around reloading".
  #8 (permalink)
Old 06-14-2011, 05:08 PM
kmonty2's Avatar
2011 Ford F-250
kmonty
it's cheap insurance. Nothing wrong with changing more often.
__________________
Kevin
  #9 (permalink)
Old 06-15-2011, 04:49 PM
2011 Ford F-250
Quote:
I'm not sure if you are reading it the right way.
If you hit "Setup" a couple of times, you will get a message stating "Oil life 100%". However if you hit "Setup" immediately followed by "Reset" you will get a whole different set of readouts including the correct oil life %. After every oil change, go back to that screen and hit "Reset" once more and it will reset it back to 100%.
Sam
  #10 (permalink)
Old 06-15-2011, 08:10 PM
Super08's Avatar
Super08 Super08 is offline
2011 Ford F-350
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
Interesting, either way I will be doing mine based on mileage. I usually dump the factory fill at 1000 miles and then after 4000. Then every 5000 after that.
__________________
2012 Ram 3500 Laramie DRW
gone but not forgotten...2011 F350 CC SB Lariat 6.2 4WD 4.30's
  #11 (permalink)
Old 06-16-2011, 11:11 AM
Sam
AND do what I do, bump the reset down 4 times to 60%, and you wil start at 60% and the reminder will trigger roughly at 5,000 miles....
  #12 (permalink)
Old 07-09-2011, 06:48 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Using bulk CP oil at work which is the same as the Motorcraft oil and with baseline UOA's on each new unit 91 in all! Average oil change according to the oil life monitor and UOA's its right about 7200 for all the trucks. All show very little wear metals and average less than a quart of make up oil between changes. We use CAT labs for our testing so all the trucks are now on a constant 7500 OCI. With a fleet this size that adds up to thousands of dollars saved and prevents waste of oil. We have 45 more trucks on order but the outfitter building them can't keep up! So far the 6.2 is working very well!!! By the end of this year we should have at least 20 trucks with over 100k on them! That will be the test!!! We get new trucks every 2 years and they are beaten and abused but well maintained and average about 150k when we dump them at auction. Fords are the only ones that have not fallen apart on us! I have very high hopes for this engine and look forward to great service from it!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
