1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Door blend motor replacement on 2008 f450
Old 06-11-2011, 01:47 AM
BigBubbs25's Avatar
BigBubbs25
BigBubbs25 is offline
Anyone had this go on their truck? Dealer told me mine needs to be replaced and it would cos over $900 just in labor plus $65 for the part. Has anyone does it their self, and is it as hard as the dealer says?
Old 06-11-2011, 05:23 PM
WhiteEx's Avatar
WhiteEx
WhiteEx is offline
There is a TSB about the '08 blend doors and they will replace them under warranty- providing you have less than 36,000 miles. I didn't find out about it until I was past 36K, so mine are not done. The entire dash has to be removed, and of course, re-installed. It is a 7-9 hour job, which is why I have not tackled the job myself.
Old 06-11-2011, 07:12 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
yup, dash removal. I would think a manual is needed before trying to take that dash all apart
Old 06-12-2011, 08:43 AM
WhiteEx's Avatar
WhiteEx
WhiteEx is offline
I've got the Helms manuals, and working around and under the dash is what I do best. I used to install radios, lights, sirens, etc. on our squad cars. On my '85 F350, I added a second fuel gauge (for the second tank) in the dash, and changed the idiot lights out to gauges. But the blend doors are about as far into the dash as you can go. I would also have to remove a CB radio, air compressor controls and air gauges, before even starting on the dash. So I'm going to live with AC blowing out the left vents and heat coming out of the right vents. It's mostly my passenger's problem anyway.
Old 06-12-2011, 01:09 PM
BigBubbs25's Avatar
BigBubbs25
Where did you find the TSB for the unit?
Old 06-12-2011, 03:20 PM
WhiteEx's Avatar
WhiteEx
WhiteEx is offline
Sorry, but it took me a while to locate it. The TSB is 09-12-15 and it can be found here: 09-12-15*** LARGE TEMPERATURE DIFFERENCES - BUILD BEFORE 11/6/2008
Also, you can do a search on blend doors, right above the first post on this page, there is a tab that says: Search This Post.
Old 06-12-2011, 04:49 PM
BigBubbs25's Avatar
BigBubbs25
Awsome thank you very much, I will be calling the dealer tomorrow since I only have 32k on the truck
Resalto.jones
6.4L Power Stroke Diesel
02-02-2016 05:23 PM
JYdvm
16
02-09-2013 12:32 PM
pjw2565
1983 - 2012 Ranger & B-Series
21
11-02-2005 04:23 PM
Okiedokie
1997 - 2003 F150
18
06-17-2005 02:00 PM
homer4111
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-03-2005 06:15 PM
Quick Reply: Door blend motor replacement on 2008 f450
