04 Escape Turning Vibration
Loose steering linkage, worn bushings, worn constant velocity joints, bad tie rod ends, loose bearings, bent wheel, worn ball joint, loose pinch bolt could all cause or allow vibration.
Please tell when the vibration occurs, such as cornering in town, or on the highway at speed, or turning out of a parking lot.
tom
tom
I gather it is not shaking the steering wheel, just making a humming. When you have noise that comes and goes by turning the steering wheel back and forth, you are unloading and loading either side of the tires more than in straight ahead driving. I would inspect the wheel bearings as I think one of them is going out.
tom
tom
bkvanbek
11-26-2013 06:05 PM
